S32 debug probe change network ports
已解决
跳至解决方案
4,382 次查看
jochengerster
HI
customer ask if below listed ports (used by S32 debug probe) can be changed ?
thanks
best regards
Jochen
标签 (1)
1 解答
4,302 次查看
Mehul_Patel_NXP
Hi, @jochengerster ,
Sorry, for delayed response,
in the document Port 41474 is typo, it should be 41475. first two mentioned ports, i.e. 23 and 1087 can not be changed
The port 41475 is used by CCS (low level debug application). CCS is mentioned in the user guide. This port can be changed in CCS as below:
Please can you ask the customer what exactly the requirement, or more information why he/she wants to change the port number?
I have also attached the updated user guide, Please find the attached and you can forward to the customer.
Thank you. Kind regards.
-Mehul Patel
在原帖中查看解决方案
3 回复数
4,289 次查看
jochengerster
Customer had problem due to IT security settings blocking the access - maybe the typo already was the problem that he requested to open the wrong port.
Good to know that the control port can be changed
thanks for your help
best regards
Jochen
4,303 次查看
Mehul_Patel_NXP
-Mehul Patel
4,344 次查看
Daniel-Aguirre
We are not seeing any information that looks as if it is possible. The chapter that relates to configuration commands is the "S32 Debug Probe setup utility commands and variables" one [Page 21, S32 Debug Probe, User Guide, Rev. 2.0, 02/2020].
Aside from this, we do not see anything else.
Please, let us know.
