S32 cannot generate *elf when compile
3,979件の閲覧回数
dizhao
Hello guys
            why my software S32 design for arm cannot gengeate *elf when compile, and my operating system is Win7.
5 返答(返信)
3,816件の閲覧回数
dizhao
yeah ,I have a default output settings.and I donnot know how ,I compile today,there are three errors show up,like the below....pastedImage_2.png
3,816件の閲覧回数
jiri_kral
Check if your ARM_TOOLCHAIN_DIR points where arm_none_eabi_gcc.exe is physically located on your hard drive:
And also try in console if the file is executable (you may be facing some encryption issues):
Jiri
3,816件の閲覧回数
dizhao
Can you tell me why, Thanks
3,816件の閲覧回数
jiri_kral
If you remove creating .srec file, are you able get .elf file? From the output it looks like that the .elf is missing as a .srec source. Any other error messages in console?
Do you have default output settings like on this screenshot (in project properties):
Jiri
3,816件の閲覧回数
jiri_kral
can you please show output from build console?
Jiri
