S32 Simulation
S32 Simulation
文辉王
程序编译可以通过,但是仿真的时候出现错误。希望有人可以帮忙解答。
The search found that the problem lies in these lines of code. Because these lines of code are used in many places, it is inevitable, so please help me to guide you.
regards,
Vern
martin_kovar
could you please share the project you are trying to debug? Which version of S32DE you use?
Martin
文辉王
I'm very sorry, I just found out that my first line is Chinese. My program is controlled and I can not send it to you. Debugging found that it is not a few lines of code, but the interruption of the problem, I will be interrupted interrupted debugging is ok.
Vern
