S32 Design Studio for Power Architecture Version 2017.R1 工程使用Clean后无法清除文件
Caihy
编译器版本:
Version: 2017.R1
Build id: 171018
添加工程后可以正常完成编译,但点击Clean后无法对已编译的内容进行清除,再次点击Build无法重新编译,手动删除文件夹之后,才可以重新编译。如果解决该问题?
S32DS For Arm版本的没发现该问题。
jiri_kral
Compiler version:
Version: 2017.R1
Build id: 171018
After adding the project, the compilation can be completed normally, but after clicking Clean, the compiled content cannot be cleared. Clicking Build again cannot recompile. After manually deleting the folder, it can be recompiled. How to solve this problem?
The S32DS For Arm version did not find this problem.
did you try to create a new workspace? Is the behavior same?
