S32 Design Studio for ARM 1.3 License missing
ソリューションへジャンプ
4,512件の閲覧回数
bongkwanpark
Hi.
S32 Design Studio for ARM License missing error
How can i solve it?
Thanks!
4,499件の閲覧回数
mikedoidge
Hello @bongkwanpark,
This error is due to the fact your license expired on 16 June, 2021. I have extended your license through 2025. Please try again, you may need to re-activate it, just use same code as before.
Mike
4 返答(返信)
4,227件の閲覧回数
permpc
I face this problem too, S32 Design Studio for ARM license missing
I try to re-activate with same code as before, but error
4,216件の閲覧回数
mikedoidge
Hello @permpc,
I checked your account. I see you currently have an active license which expires in the year 2025.
Probably your issue is different. Could you share a picture of the exact error message you are receiving?
It is possible there is some issue with the trusted storage, please try the following and then try to open S32DS again:
delete C:\ProgramData\FLEXNet.
For Linux installations:
/usr/local/share/macrovision/storage
Mike
4,187件の閲覧回数
permpc
@mikedoidge
That is worked, Thank you for your suggestion.
4,500件の閲覧回数
mikedoidge
Mike
