S32 Design Studio IDE installation error
4,463件の閲覧回数
StrayCat
Dear NXP Community,
I have a problem installing S32 Design Studio IDE on my machine. Installation is aborted and rolled back very early in the process (before activation). The error message is something along the lines "Insufficient Windows user permissions". But the software is installed with admin rights. My system is Windows 10 Enterprise 64 bit
Here's full log:
スポイラ
__________________________________________________________________________
Wed Sep 13 12:51:22 CEST 2023
Free Memory: 42384 kB
Total Memory: 61440 kB
java.class.path:
C:\Users\UserName\AppData\Local\Temp\I1694601925\InstallerData\IAClasses.zip
C:\Users\UserName\AppData\Local\Temp\I1694601925\InstallerData\Execute.zip
C:\Users\UserName\AppData\Local\Temp\I1694601925\Windows\InstallerData\Execute.zip
C:\Users\UserName\AppData\Local\Temp\I1694601925\InstallerData\Resource1.zip
C:\Users\UserName\AppData\Local\Temp\I1694601925\Windows\InstallerData\Resource1.zip
ZGUtil.CLASS_PATH:
sun.boot.class.path:
<none specified>
java.ext.dirs:
<none specified>
java.version == 11.0.11 (Java 1)
java.vm.name == OpenJDK 64-Bit Server VM
java.vm.vendor == AdoptOpenJDK
java.vm.version == 11.0.11+9
java.vm.specification.name == Java Virtual Machine Specification
java.vm.specification.vendor == Oracle Corporation
java.vm.specification.version == 11
java.specification.name == Java Platform API Specification
java.specification.vendor == Oracle Corporation
java.specification.version == 11
java.vendor == AdoptOpenJDK
java.vendor.url == https://adoptopenjdk.net/
java.class.version == 55.0
java.library.path == C:\Users\UserName\AppData\Local\Temp\I1694601925\Windows\resource\jre\bin;C:\windows\Sun\Java\bin;C:\windows\system32;C:\windows;C:\ProgramData\Oracle\Java\javapath;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\windows\System32\OpenSSH\;c:\Program Files\Intel\WiFi\bin\;c:\Program Files\Common Files\Intel\WirelessCommon\;C:\Program Files (x86)\Pulse Secure\VC142.CRT\X64\;C:\Program Files (x86)\Pulse Secure\VC142.CRT\X86\;C:\Program Files (x86)\Common Files\Pulse Secure\TNC Client Plugin\;C:\Users\UserName\AppData\Local\Microsoft\WindowsApps;.
java.compiler == null
java.home == C:\Users\UserName\AppData\Local\Temp\I1694601925\Windows\resource\jre
java.io.tmpdir == C:\Users\UserName\AppData\Local\Temp\
os.name == Microsoft Windows 10 Enterprise
os.arch == amd64
os.version == 10.0.19045
path.separator == ;
file.separator == \
file.encoding == Cp1252
user.name == UserName
user.home == C:\Users\UserName
user.dir == C:\Users\UserName\AppData\Local\Temp\I1694601925\Windows
user.language == en
user.region == null
Installed Feature(s) S32DSF of S32 Design Studio for S32 Platform 3.5
Install Begin: SEPTEMBER 13, 2023 12:50:18 PM CEST
Install End: SEPTEMBER 13, 2023 12:51:01 PM CEST
Installed by InstallAnywhere 21.0 Premier Build 6581
User Interactions
#Choose Install Location
USER_INSTALL_DIR=C:\\NXP\\S32DS.3.5
#Choose Shortcut Folder
USER_SHORTCUTS=Do Not Install
#Install
-fileOverwrite_C\:\\NXP\\S32DS.3.5\\_S32\ Design\ Studio\ for\ S32\ Platform\ 3.5_installation\\resource\\iawin64_x64.dll=Yes
-fileOverwrite_C\:\\NXP\\S32DS.3.5\\_S32\ Design\ Studio\ for\ S32\ Platform\ 3.5_installation\\resource\\iawin32.dll=Yes
-fileOverwrite_C\:\\NXP\\S32DS.3.5\\_S32\ Design\ Studio\ for\ S32\ Platform\ 3.5_installation\\resource\\win64_32_x64.exe=Yes
-fileOverwrite_C\:\\NXP\\S32DS.3.5\\_S32\ Design\ Studio\ for\ S32\ Platform\ 3.5_installation\\resource\\remove.exe=Yes
-fileOverwrite_C\:\\NXP\\S32DS.3.5\\_S32\ Design\ Studio\ for\ S32\ Platform\ 3.5_installation\\resource\\invoker.exe=Yes
Summary
Installation: Unsuccessful.
34 Successes
0 Warnings
1 NonFatalErrors
1 FatalErrors
Action Notes:
None
Install Log Detail:
Check Disk Space: C:\NXP\S32DS.3.5
Status: SUCCESSFUL
Additional Notes: NOTE - Required Disk Space:4,454,120,040 Bytes Free Disk Space:157,790,625,792 Bytes
Status: SUCCESSFUL
Get Registry Entry: Key: HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\VirtualizerRuntime-M-2017.06-171108
Value Name: InstallLocation
Status: SUCCESSFUL
Get Registry Entry: Key: HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\VirtualizerRuntime-M-2017.06-180110
Status: SUCCESSFUL
Get Registry Entry: Key: HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\VirtualizerRuntime-M-2017.06-180223
Status: SUCCESSFUL
Get Registry Entry: Key: HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\VirtualizerRuntime-M-2017.06-180403
Status: SUCCESSFUL
Get Registry Entry: Key: HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\VirtualizerRuntime-M-2017.06-180720
Status: SUCCESSFUL
Get Registry Entry: Key: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Uninstall\{4b12c27c-689d-42cd-a475-ba2c4fdd2e2b}
Status: SUCCESSFUL
Status: SUCCESSFUL
Additional Notes: NOTE - Required Disk Space:4,454,120,040 Bytes Free Disk Space:157,790,584,832 Bytes
Install Directory: C:\NXP\S32DS.3.5\jre
Status: SUCCESSFUL
Install JRE: C:\NXP\S32DS.3.5\jre
Status: SUCCESSFUL
Install Directory: C:\Users\UserName\AppData\Local\Temp\735805.tmp\
Status: SUCCESSFUL
Additional Notes: NOTE - Directory already existed
Execute Command: NET SESSION
Status: SUCCESSFUL
Execute Command: ping 1.1.1.1 -n 1 -w 5000
Status: SUCCESSFUL
Install Uninstaller: S32 Design Studio for S32 Platform 3.5(Install All Uninstaller Components)
Status: SUCCESSFUL
Install Directory: C:\NXP\S32DS.3.5\_S32 Design Studio for S32 Platform 3.5_installation\resource\
Status: SUCCESSFUL
Install File: C:\NXP\S32DS.3.5\_S32 Design Studio for S32 Platform 3.5_installation\resource\iawin64_x64.dll
Status: SUCCESSFUL
Install File: C:\NXP\S32DS.3.5\_S32 Design Studio for S32 Platform 3.5_installation\resource\iawin32.dll
Status: SUCCESSFUL
Install File: C:\NXP\S32DS.3.5\_S32 Design Studio for S32 Platform 3.5_installation\resource\win64_32_x64.exe
Status: SUCCESSFUL
Install File: C:\NXP\S32DS.3.5\_S32 Design Studio for S32 Platform 3.5_installation\resource\remove.exe
Status: SUCCESSFUL
Install File: C:\NXP\S32DS.3.5\_S32 Design Studio for S32 Platform 3.5_installation\resource\invoker.exe
Status: SUCCESSFUL
Make Registry Entry: Key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\S32 Design Studio for S32 Platform 3.5
Value Name: EstimatedSize
Value Data: 426ec7
Status: SUCCESSFUL
Status: ERROR
Additional Notes: ERROR - Error writing LaunchAnywhere components (Access Denied)
Uninstall Folder: C:\NXP\S32DS.3.5\jre
Status: SUCCESSFUL
Status: SUCCESSFUL
Status: SUCCESSFUL
Delete File: Source:s32ds.bat
Status: SUCCESSFUL
Additional Notes: NOTE - Source file s32ds.bat does not exist.
Status: SUCCESSFUL
Delete File: Source:Welcome.txt
Status: SUCCESSFUL
Additional Notes: NOTE - Source file Welcome.txt does not exist.
Remove Registry Entry: 5 HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\null
Status: SUCCESSFUL
Error occurred while installing the following Action, hence rolling back the installation....!
Action Name: Trigger Rollback Action
Action Description: Trigger Rollback Action
Error Details as below:
This action rolls back the Installation.
====================STDERR ENTRIES==================
InstallAnywhere 2021
Version: 21.0
Wed Sep 13 12:50:15 CEST 2023
Free Memory: 10743 kB
Total Memory: 16384 kB
No Arguments
java.class.path:
ZGUtil.CLASS_PATH:
<none specified>
java.ext.dirs:
<none specified>
os.arch == amd64
path.separator == ;
file.separator == \
user.language == en
user.region == null
Loading externalized properties
RepositoryManager: Trying fallback repository location...
==== Installer properties log start: ====
User Install directory: C:\NXP\S32DS.3.5
User Shortcuts: C:\Users\UserName\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\NXP S32 Design Studio\S32 Design Studio for S32 Platform 3.5
==== Installer properties log end. ====
# INSTALLING VM: C:\NXP\S32DS.3.5\jre
System's temporary directory = C:\Users\UserName\AppData\Local\Temp
==== NET SESSION command log start: ====
Returned: 2
Console:
Errors: The Server service is not started.
More help is available by typing NET HELPMSG 2114.
==== NET SESSION command log end. ====
XMLScriptWriter: No Installation Objects were skipped
8. final log file name=C:\NXP\S32DS.3.5\_S32 Design Studio for S32 Platform 3.5_installation\Logs\S32_Design_Studio_for_S32_Platform_3.5_Install_09_13_2023_12_51_22.log
====================STDOUT ENTRIES==================
C:\NXP\S32DS.3.5\jre\bin
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-core-console-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-core-datetime-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-core-debug-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-core-errorhandling-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-core-file-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-core-file-l1-2-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-core-file-l2-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-core-handle-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-core-heap-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-core-interlocked-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-core-libraryloader-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-core-localization-l1-2-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-core-memory-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-core-namedpipe-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-core-processenvironment-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-core-processthreads-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-core-processthreads-l1-1-1.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-core-profile-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-core-rtlsupport-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-core-string-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-core-synch-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-core-synch-l1-2-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-core-sysinfo-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-core-timezone-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-core-util-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-crt-conio-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-crt-convert-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-crt-environment-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-crt-filesystem-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-crt-heap-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-crt-locale-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-crt-math-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-crt-multibyte-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-crt-private-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-crt-process-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-crt-runtime-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-crt-stdio-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-crt-string-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-crt-time-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\api-ms-win-crt-utility-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\bin\attach.dll
C:\NXP\S32DS.3.5\jre\bin\awt.dll
C:\NXP\S32DS.3.5\jre\bin\client
C:\NXP\S32DS.3.5\jre\bin\client\jvm.dll
C:\NXP\S32DS.3.5\jre\bin\dt_shmem.dll
C:\NXP\S32DS.3.5\jre\bin\dt_socket.dll
C:\NXP\S32DS.3.5\jre\bin\fontmanager.dll
C:\NXP\S32DS.3.5\jre\bin\freetype.dll
C:\NXP\S32DS.3.5\jre\bin\harfbuzz.dll
C:\NXP\S32DS.3.5\jre\bin\instrument.dll
C:\NXP\S32DS.3.5\jre\bin\j2gss.dll
C:\NXP\S32DS.3.5\jre\bin\j2pcsc.dll
C:\NXP\S32DS.3.5\jre\bin\j2pkcs11.dll
C:\NXP\S32DS.3.5\jre\bin\jaas.dll
C:\NXP\S32DS.3.5\jre\bin\jabswitch.exe
C:\NXP\S32DS.3.5\jre\bin\jaccessinspector.exe
C:\NXP\S32DS.3.5\jre\bin\jaccesswalker.exe
C:\NXP\S32DS.3.5\jre\bin\jaotc.exe
C:\NXP\S32DS.3.5\jre\bin\jar.exe
C:\NXP\S32DS.3.5\jre\bin\jarsigner.exe
C:\NXP\S32DS.3.5\jre\bin\java.dll
C:\NXP\S32DS.3.5\jre\bin\java.exe
C:\NXP\S32DS.3.5\jre\bin\javaaccessbridge.dll
C:\NXP\S32DS.3.5\jre\bin\javac.exe
C:\NXP\S32DS.3.5\jre\bin\javadoc.exe
C:\NXP\S32DS.3.5\jre\bin\javajpeg.dll
C:\NXP\S32DS.3.5\jre\bin\javap.exe
C:\NXP\S32DS.3.5\jre\bin\javaw.exe
C:\NXP\S32DS.3.5\jre\bin\jawt.dll
C:\NXP\S32DS.3.5\jre\bin\jcmd.exe
C:\NXP\S32DS.3.5\jre\bin\jconsole.exe
C:\NXP\S32DS.3.5\jre\bin\jdb.exe
C:\NXP\S32DS.3.5\jre\bin\jdeprscan.exe
C:\NXP\S32DS.3.5\jre\bin\jdeps.exe
C:\NXP\S32DS.3.5\jre\bin\jdwp.dll
C:\NXP\S32DS.3.5\jre\bin\jfr.exe
C:\NXP\S32DS.3.5\jre\bin\jhsdb.exe
C:\NXP\S32DS.3.5\jre\bin\jimage.dll
C:\NXP\S32DS.3.5\jre\bin\jimage.exe
C:\NXP\S32DS.3.5\jre\bin\jinfo.exe
C:\NXP\S32DS.3.5\jre\bin\jjs.exe
C:\NXP\S32DS.3.5\jre\bin\jli.dll
C:\NXP\S32DS.3.5\jre\bin\jlink.exe
C:\NXP\S32DS.3.5\jre\bin\jmap.exe
C:\NXP\S32DS.3.5\jre\bin\jmod.exe
C:\NXP\S32DS.3.5\jre\bin\jps.exe
C:\NXP\S32DS.3.5\jre\bin\jrunscript.exe
C:\NXP\S32DS.3.5\jre\bin\jshell.exe
C:\NXP\S32DS.3.5\jre\bin\jsound.dll
C:\NXP\S32DS.3.5\jre\bin\jstack.exe
C:\NXP\S32DS.3.5\jre\bin\jstat.exe
C:\NXP\S32DS.3.5\jre\bin\jstatd.exe
C:\NXP\S32DS.3.5\jre\bin\keytool.exe
C:\NXP\S32DS.3.5\jre\bin\kinit.exe
C:\NXP\S32DS.3.5\jre\bin\klist.exe
C:\NXP\S32DS.3.5\jre\bin\ktab.exe
C:\NXP\S32DS.3.5\jre\bin\lcms.dll
C:\NXP\S32DS.3.5\jre\bin\le.dll
C:\NXP\S32DS.3.5\jre\bin\management.dll
C:\NXP\S32DS.3.5\jre\bin\management_agent.dll
C:\NXP\S32DS.3.5\jre\bin\management_ext.dll
C:\NXP\S32DS.3.5\jre\bin\mlib_image.dll
C:\NXP\S32DS.3.5\jre\bin\msvcp140.dll
C:\NXP\S32DS.3.5\jre\bin\net.dll
C:\NXP\S32DS.3.5\jre\bin\nio.dll
C:\NXP\S32DS.3.5\jre\bin\pack200.exe
C:\NXP\S32DS.3.5\jre\bin\prefs.dll
C:\NXP\S32DS.3.5\jre\bin\rmi.dll
C:\NXP\S32DS.3.5\jre\bin\rmic.exe
C:\NXP\S32DS.3.5\jre\bin\rmid.exe
C:\NXP\S32DS.3.5\jre\bin\rmiregistry.exe
C:\NXP\S32DS.3.5\jre\bin\saproc.dll
C:\NXP\S32DS.3.5\jre\bin\serialver.exe
C:\NXP\S32DS.3.5\jre\bin\server
C:\NXP\S32DS.3.5\jre\bin\server\jvm.dll
C:\NXP\S32DS.3.5\jre\bin\splashscreen.dll
C:\NXP\S32DS.3.5\jre\bin\sspi_bridge.dll
C:\NXP\S32DS.3.5\jre\bin\sunec.dll
C:\NXP\S32DS.3.5\jre\bin\sunmscapi.dll
C:\NXP\S32DS.3.5\jre\bin\ucrtbase.dll
C:\NXP\S32DS.3.5\jre\bin\unpack.dll
C:\NXP\S32DS.3.5\jre\bin\unpack200.exe
C:\NXP\S32DS.3.5\jre\bin\vcruntime140.dll
C:\NXP\S32DS.3.5\jre\bin\verify.dll
C:\NXP\S32DS.3.5\jre\bin\w2k_lsa_auth.dll
C:\NXP\S32DS.3.5\jre\bin\windowsaccessbridge-64.dll
C:\NXP\S32DS.3.5\jre\bin\zip.dll
C:\NXP\S32DS.3.5\jre\conf
C:\NXP\S32DS.3.5\jre\conf\logging.properties
C:\NXP\S32DS.3.5\jre\conf\management
C:\NXP\S32DS.3.5\jre\conf\management\jmxremote.access
C:\NXP\S32DS.3.5\jre\conf\management\jmxremote.password.template
C:\NXP\S32DS.3.5\jre\conf\management\management.properties
C:\NXP\S32DS.3.5\jre\conf\net.properties
C:\NXP\S32DS.3.5\jre\conf\security
C:\NXP\S32DS.3.5\jre\conf\security\java.policy
C:\NXP\S32DS.3.5\jre\conf\security\java.security
C:\NXP\S32DS.3.5\jre\conf\security\policy
C:\NXP\S32DS.3.5\jre\conf\security\policy\limited
C:\NXP\S32DS.3.5\jre\conf\security\policy\limited\default_local.policy
C:\NXP\S32DS.3.5\jre\conf\security\policy\limited\default_US_export.policy
C:\NXP\S32DS.3.5\jre\conf\security\policy\limited\exempt_local.policy
C:\NXP\S32DS.3.5\jre\conf\security\policy\README.txt
C:\NXP\S32DS.3.5\jre\conf\security\policy\unlimited
C:\NXP\S32DS.3.5\jre\conf\security\policy\unlimited\default_local.policy
C:\NXP\S32DS.3.5\jre\conf\security\policy\unlimited\default_US_export.policy
C:\NXP\S32DS.3.5\jre\conf\sound.properties
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-core-console-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-core-datetime-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-core-debug-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-core-errorhandling-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-core-file-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-core-file-l1-2-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-core-file-l2-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-core-handle-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-core-heap-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-core-interlocked-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-core-libraryloader-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-core-localization-l1-2-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-core-memory-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-core-namedpipe-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-core-processenvironment-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-core-processthreads-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-core-processthreads-l1-1-1.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-core-profile-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-core-rtlsupport-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-core-string-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-core-synch-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-core-synch-l1-2-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-core-sysinfo-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-core-timezone-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-core-util-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-crt-conio-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-crt-convert-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-crt-environment-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-crt-filesystem-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-crt-heap-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-crt-locale-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-crt-math-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-crt-multibyte-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-crt-private-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-crt-process-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-crt-runtime-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-crt-stdio-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-crt-string-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-crt-time-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\api-ms-win-crt-utility-l1-1-0.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\concrt140.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\decora_sse.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\fxplugins.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\glass.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\glib-lite.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\gstreamer-lite.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\javafx_font.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\javafx_iio.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\jfxmedia.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\jfxwebkit.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\msvcp140.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\prism_common.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\prism_d3d.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\prism_sw.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\ucrtbase.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\bin\vcruntime140.dll
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.base
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.base\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.base\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.base\LICENSE
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.controls
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.controls\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.controls\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.controls\LICENSE
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.fxml
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.fxml\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.fxml\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.fxml\LICENSE
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.graphics
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.graphics\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.graphics\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.graphics\jpeg_fx.md
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.graphics\LICENSE
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.media
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.media\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.media\applecoreaudio.md
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.media\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.media\glib.md
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.media\gstreamer.md
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.media\libffi.md
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.media\LICENSE
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.swing
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.swing\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.swing\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.swing\LICENSE
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.web
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.web\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.web\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.web\icu_web.md
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.web\libxml2.md
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.web\libxslt.md
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.web\LICENSE
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\legal\javafx.web\webkit.md
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\lib
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\lib\javafx-swt.jar
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\lib\javafx.base.jar
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\lib\javafx.controls.jar
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\lib\javafx.fxml.jar
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\lib\javafx.graphics.jar
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\lib\javafx.media.jar
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\lib\javafx.properties
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\lib\javafx.swing.jar
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\lib\javafx.web.jar
C:\NXP\S32DS.3.5\jre\javafx-sdk-11.0.2\lib\src.zip
C:\NXP\S32DS.3.5\jre\jlink.options
C:\NXP\S32DS.3.5\jre\legal
C:\NXP\S32DS.3.5\jre\legal\java.base
C:\NXP\S32DS.3.5\jre\legal\java.base\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\java.base\aes.md
C:\NXP\S32DS.3.5\jre\legal\java.base\asm.md
C:\NXP\S32DS.3.5\jre\legal\java.base\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\java.base\c-libutl.md
C:\NXP\S32DS.3.5\jre\legal\java.base\cldr.md
C:\NXP\S32DS.3.5\jre\legal\java.base\icu.md
C:\NXP\S32DS.3.5\jre\legal\java.base\LICENSE
C:\NXP\S32DS.3.5\jre\legal\java.base\public_suffix.md
C:\NXP\S32DS.3.5\jre\legal\java.base\unicode.md
C:\NXP\S32DS.3.5\jre\legal\java.base\zlib.md
C:\NXP\S32DS.3.5\jre\legal\java.compiler
C:\NXP\S32DS.3.5\jre\legal\java.compiler\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\java.compiler\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\java.compiler\LICENSE
C:\NXP\S32DS.3.5\jre\legal\java.datatransfer
C:\NXP\S32DS.3.5\jre\legal\java.datatransfer\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\java.datatransfer\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\java.datatransfer\LICENSE
C:\NXP\S32DS.3.5\jre\legal\java.desktop
C:\NXP\S32DS.3.5\jre\legal\java.desktop\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\java.desktop\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\java.desktop\colorimaging.md
C:\NXP\S32DS.3.5\jre\legal\java.desktop\freetype.md
C:\NXP\S32DS.3.5\jre\legal\java.desktop\giflib.md
C:\NXP\S32DS.3.5\jre\legal\java.desktop\harfbuzz.md
C:\NXP\S32DS.3.5\jre\legal\java.desktop\jpeg.md
C:\NXP\S32DS.3.5\jre\legal\java.desktop\lcms.md
C:\NXP\S32DS.3.5\jre\legal\java.desktop\libpng.md
C:\NXP\S32DS.3.5\jre\legal\java.desktop\LICENSE
C:\NXP\S32DS.3.5\jre\legal\java.desktop\mesa3d.md
C:\NXP\S32DS.3.5\jre\legal\java.instrument
C:\NXP\S32DS.3.5\jre\legal\java.instrument\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\java.instrument\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\java.instrument\LICENSE
C:\NXP\S32DS.3.5\jre\legal\java.logging
C:\NXP\S32DS.3.5\jre\legal\java.logging\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\java.logging\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\java.logging\LICENSE
C:\NXP\S32DS.3.5\jre\legal\java.management
C:\NXP\S32DS.3.5\jre\legal\java.management\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\java.management\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\java.management\LICENSE
C:\NXP\S32DS.3.5\jre\legal\java.management.rmi
C:\NXP\S32DS.3.5\jre\legal\java.management.rmi\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\java.management.rmi\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\java.management.rmi\LICENSE
C:\NXP\S32DS.3.5\jre\legal\java.naming
C:\NXP\S32DS.3.5\jre\legal\java.naming\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\java.naming\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\java.naming\LICENSE
C:\NXP\S32DS.3.5\jre\legal\java.net.http
C:\NXP\S32DS.3.5\jre\legal\java.net.http\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\java.net.http\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\java.net.http\LICENSE
C:\NXP\S32DS.3.5\jre\legal\java.prefs
C:\NXP\S32DS.3.5\jre\legal\java.prefs\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\java.prefs\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\java.prefs\LICENSE
C:\NXP\S32DS.3.5\jre\legal\java.rmi
C:\NXP\S32DS.3.5\jre\legal\java.rmi\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\java.rmi\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\java.rmi\LICENSE
C:\NXP\S32DS.3.5\jre\legal\java.scripting
C:\NXP\S32DS.3.5\jre\legal\java.scripting\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\java.scripting\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\java.scripting\LICENSE
C:\NXP\S32DS.3.5\jre\legal\java.se
C:\NXP\S32DS.3.5\jre\legal\java.se\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\java.se\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\java.se\LICENSE
C:\NXP\S32DS.3.5\jre\legal\java.security.jgss
C:\NXP\S32DS.3.5\jre\legal\java.security.jgss\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\java.security.jgss\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\java.security.jgss\LICENSE
C:\NXP\S32DS.3.5\jre\legal\java.security.sasl
C:\NXP\S32DS.3.5\jre\legal\java.security.sasl\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\java.security.sasl\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\java.security.sasl\LICENSE
C:\NXP\S32DS.3.5\jre\legal\java.smartcardio
C:\NXP\S32DS.3.5\jre\legal\java.smartcardio\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\java.smartcardio\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\java.smartcardio\LICENSE
C:\NXP\S32DS.3.5\jre\legal\java.sql
C:\NXP\S32DS.3.5\jre\legal\java.sql\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\java.sql\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\java.sql\LICENSE
C:\NXP\S32DS.3.5\jre\legal\java.sql.rowset
C:\NXP\S32DS.3.5\jre\legal\java.sql.rowset\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\java.sql.rowset\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\java.sql.rowset\LICENSE
C:\NXP\S32DS.3.5\jre\legal\java.transaction.xa
C:\NXP\S32DS.3.5\jre\legal\java.transaction.xa\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\java.transaction.xa\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\java.transaction.xa\LICENSE
C:\NXP\S32DS.3.5\jre\legal\java.xml
C:\NXP\S32DS.3.5\jre\legal\java.xml\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\java.xml\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\java.xml\bcel.md
C:\NXP\S32DS.3.5\jre\legal\java.xml\dom.md
C:\NXP\S32DS.3.5\jre\legal\java.xml\jcup.md
C:\NXP\S32DS.3.5\jre\legal\java.xml\LICENSE
C:\NXP\S32DS.3.5\jre\legal\java.xml\xalan.md
C:\NXP\S32DS.3.5\jre\legal\java.xml\xerces.md
C:\NXP\S32DS.3.5\jre\legal\java.xml.crypto
C:\NXP\S32DS.3.5\jre\legal\java.xml.crypto\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\java.xml.crypto\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\java.xml.crypto\LICENSE
C:\NXP\S32DS.3.5\jre\legal\java.xml.crypto\santuario.md
C:\NXP\S32DS.3.5\jre\legal\jdk.accessibility
C:\NXP\S32DS.3.5\jre\legal\jdk.accessibility\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.accessibility\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.accessibility\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.aot
C:\NXP\S32DS.3.5\jre\legal\jdk.aot\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.aot\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.aot\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.attach
C:\NXP\S32DS.3.5\jre\legal\jdk.attach\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.attach\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.attach\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.charsets
C:\NXP\S32DS.3.5\jre\legal\jdk.charsets\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.charsets\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.charsets\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.compiler
C:\NXP\S32DS.3.5\jre\legal\jdk.compiler\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.compiler\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.compiler\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.crypto.cryptoki
C:\NXP\S32DS.3.5\jre\legal\jdk.crypto.cryptoki\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.crypto.cryptoki\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.crypto.cryptoki\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.crypto.cryptoki\pkcs11cryptotoken.md
C:\NXP\S32DS.3.5\jre\legal\jdk.crypto.cryptoki\pkcs11wrapper.md
C:\NXP\S32DS.3.5\jre\legal\jdk.crypto.ec
C:\NXP\S32DS.3.5\jre\legal\jdk.crypto.ec\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.crypto.ec\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.crypto.ec\ecc.md
C:\NXP\S32DS.3.5\jre\legal\jdk.crypto.ec\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.crypto.mscapi
C:\NXP\S32DS.3.5\jre\legal\jdk.crypto.mscapi\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.crypto.mscapi\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.crypto.mscapi\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.dynalink
C:\NXP\S32DS.3.5\jre\legal\jdk.dynalink\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.dynalink\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.dynalink\dynalink.md
C:\NXP\S32DS.3.5\jre\legal\jdk.dynalink\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.editpad
C:\NXP\S32DS.3.5\jre\legal\jdk.editpad\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.editpad\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.editpad\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.hotspot.agent
C:\NXP\S32DS.3.5\jre\legal\jdk.hotspot.agent\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.hotspot.agent\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.hotspot.agent\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.httpserver
C:\NXP\S32DS.3.5\jre\legal\jdk.httpserver\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.httpserver\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.httpserver\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.internal.ed
C:\NXP\S32DS.3.5\jre\legal\jdk.internal.ed\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.internal.ed\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.internal.ed\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.internal.jvmstat
C:\NXP\S32DS.3.5\jre\legal\jdk.internal.jvmstat\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.internal.jvmstat\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.internal.jvmstat\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.internal.le
C:\NXP\S32DS.3.5\jre\legal\jdk.internal.le\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.internal.le\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.internal.le\jline.md
C:\NXP\S32DS.3.5\jre\legal\jdk.internal.le\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.internal.opt
C:\NXP\S32DS.3.5\jre\legal\jdk.internal.opt\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.internal.opt\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.internal.opt\jopt-simple.md
C:\NXP\S32DS.3.5\jre\legal\jdk.internal.opt\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.internal.vm.ci
C:\NXP\S32DS.3.5\jre\legal\jdk.internal.vm.ci\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.internal.vm.ci\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.internal.vm.ci\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.internal.vm.compiler
C:\NXP\S32DS.3.5\jre\legal\jdk.internal.vm.compiler\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.internal.vm.compiler\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.internal.vm.compiler\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.internal.vm.compiler.management
C:\NXP\S32DS.3.5\jre\legal\jdk.internal.vm.compiler.management\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.internal.vm.compiler.management\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.internal.vm.compiler.management\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.jartool
C:\NXP\S32DS.3.5\jre\legal\jdk.jartool\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.jartool\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.jartool\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.javadoc
C:\NXP\S32DS.3.5\jre\legal\jdk.javadoc\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.javadoc\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.javadoc\jquery.md
C:\NXP\S32DS.3.5\jre\legal\jdk.javadoc\jqueryUI.md
C:\NXP\S32DS.3.5\jre\legal\jdk.javadoc\jszip.md
C:\NXP\S32DS.3.5\jre\legal\jdk.javadoc\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.javadoc\pako.md
C:\NXP\S32DS.3.5\jre\legal\jdk.jcmd
C:\NXP\S32DS.3.5\jre\legal\jdk.jcmd\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.jcmd\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.jcmd\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.jconsole
C:\NXP\S32DS.3.5\jre\legal\jdk.jconsole\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.jconsole\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.jconsole\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.jdeps
C:\NXP\S32DS.3.5\jre\legal\jdk.jdeps\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.jdeps\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.jdeps\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.jdi
C:\NXP\S32DS.3.5\jre\legal\jdk.jdi\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.jdi\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.jdi\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.jdwp.agent
C:\NXP\S32DS.3.5\jre\legal\jdk.jdwp.agent\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.jdwp.agent\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.jdwp.agent\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.jfr
C:\NXP\S32DS.3.5\jre\legal\jdk.jfr\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.jfr\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.jfr\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.jlink
C:\NXP\S32DS.3.5\jre\legal\jdk.jlink\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.jlink\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.jlink\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.jshell
C:\NXP\S32DS.3.5\jre\legal\jdk.jshell\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.jshell\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.jshell\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.jsobject
C:\NXP\S32DS.3.5\jre\legal\jdk.jsobject\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.jsobject\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.jsobject\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.jstatd
C:\NXP\S32DS.3.5\jre\legal\jdk.jstatd\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.jstatd\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.jstatd\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.localedata
C:\NXP\S32DS.3.5\jre\legal\jdk.localedata\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.localedata\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.localedata\cldr.md
C:\NXP\S32DS.3.5\jre\legal\jdk.localedata\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.localedata\thaidict.md
C:\NXP\S32DS.3.5\jre\legal\jdk.management
C:\NXP\S32DS.3.5\jre\legal\jdk.management\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.management\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.management\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.management.agent
C:\NXP\S32DS.3.5\jre\legal\jdk.management.agent\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.management.agent\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.management.agent\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.management.jfr
C:\NXP\S32DS.3.5\jre\legal\jdk.management.jfr\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.management.jfr\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.management.jfr\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.naming.dns
C:\NXP\S32DS.3.5\jre\legal\jdk.naming.dns\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.naming.dns\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.naming.dns\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.naming.ldap
C:\NXP\S32DS.3.5\jre\legal\jdk.naming.ldap\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.naming.ldap\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.naming.ldap\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.naming.rmi
C:\NXP\S32DS.3.5\jre\legal\jdk.naming.rmi\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.naming.rmi\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.naming.rmi\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.net
C:\NXP\S32DS.3.5\jre\legal\jdk.net\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.net\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.net\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.pack
C:\NXP\S32DS.3.5\jre\legal\jdk.pack\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.pack\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.pack\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.rmic
C:\NXP\S32DS.3.5\jre\legal\jdk.rmic\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.rmic\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.rmic\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.scripting.nashorn
C:\NXP\S32DS.3.5\jre\legal\jdk.scripting.nashorn\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.scripting.nashorn\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.scripting.nashorn\double-conversion.md
C:\NXP\S32DS.3.5\jre\legal\jdk.scripting.nashorn\joni.md
C:\NXP\S32DS.3.5\jre\legal\jdk.scripting.nashorn\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.scripting.nashorn.shell
C:\NXP\S32DS.3.5\jre\legal\jdk.scripting.nashorn.shell\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.scripting.nashorn.shell\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.scripting.nashorn.shell\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.sctp
C:\NXP\S32DS.3.5\jre\legal\jdk.sctp\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.sctp\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.sctp\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.security.auth
C:\NXP\S32DS.3.5\jre\legal\jdk.security.auth\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.security.auth\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.security.auth\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.security.jgss
C:\NXP\S32DS.3.5\jre\legal\jdk.security.jgss\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.security.jgss\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.security.jgss\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.unsupported
C:\NXP\S32DS.3.5\jre\legal\jdk.unsupported\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.unsupported\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.unsupported\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.unsupported.desktop
C:\NXP\S32DS.3.5\jre\legal\jdk.unsupported.desktop\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.unsupported.desktop\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.unsupported.desktop\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.xml.dom
C:\NXP\S32DS.3.5\jre\legal\jdk.xml.dom\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.xml.dom\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.xml.dom\LICENSE
C:\NXP\S32DS.3.5\jre\legal\jdk.zipfs
C:\NXP\S32DS.3.5\jre\legal\jdk.zipfs\ADDITIONAL_LICENSE_INFO
C:\NXP\S32DS.3.5\jre\legal\jdk.zipfs\ASSEMBLY_EXCEPTION
C:\NXP\S32DS.3.5\jre\legal\jdk.zipfs\LICENSE
C:\NXP\S32DS.3.5\jre\lib
C:\NXP\S32DS.3.5\jre\lib\classlist
C:\NXP\S32DS.3.5\jre\lib\client
C:\NXP\S32DS.3.5\jre\lib\client\Xusage.txt
C:\NXP\S32DS.3.5\jre\lib\ct.sym
C:\NXP\S32DS.3.5\jre\lib\fontconfig.bfc
C:\NXP\S32DS.3.5\jre\lib\fontconfig.properties.src
C:\NXP\S32DS.3.5\jre\lib\jawt.lib
C:\NXP\S32DS.3.5\jre\lib\jfr
C:\NXP\S32DS.3.5\jre\lib\jfr\default.jfc
C:\NXP\S32DS.3.5\jre\lib\jfr\profile.jfc
C:\NXP\S32DS.3.5\jre\lib\jrt-fs.jar
C:\NXP\S32DS.3.5\jre\lib\jvm.cfg
C:\NXP\S32DS.3.5\jre\lib\jvm.lib
C:\NXP\S32DS.3.5\jre\lib\modules
C:\NXP\S32DS.3.5\jre\lib\psfont.properties.ja
C:\NXP\S32DS.3.5\jre\lib\psfontj2d.properties
C:\NXP\S32DS.3.5\jre\lib\security
C:\NXP\S32DS.3.5\jre\lib\security\blacklisted.certs
C:\NXP\S32DS.3.5\jre\lib\security\cacerts
C:\NXP\S32DS.3.5\jre\lib\security\default.policy
C:\NXP\S32DS.3.5\jre\lib\security\public_suffix_list.dat
C:\NXP\S32DS.3.5\jre\lib\server
C:\NXP\S32DS.3.5\jre\lib\server\Xusage.txt
C:\NXP\S32DS.3.5\jre\lib\tzdb.dat
C:\NXP\S32DS.3.5\jre\lib\tzmappings
C:\NXP\S32DS.3.5\jre\release
C:\NXP\S32DS.3.5\_S32 Design Studio for S32 Platform 3.5_installation\.com.zerog.registry.xml
C:\NXP\S32DS.3.5\_S32 Design Studio for S32 Platform 3.5_installation\InstallScript.iap_xml
C:\NXP\S32DS.3.5\_S32 Design Studio for S32 Platform 3.5_installation\uninstaller.jar
There is this line during Java Virtual Machine installation that says "Errors: The Server service is not started.". Thing is we have very strict security policy in our company so the Server service is disabled permanently on our computers. Yet I was still able to install S32 Design Studio on my previous company laptop with the same restrictions.
I'll appreciate any help.
Cheers,
Przemek.
4,441件の閲覧回数
Mehul_Patel_NXP
Hi, @StrayCat ,
From the log as understood the issue is because of administrator rights.
Your Windows user account must be a member of the administrator's group. The 'Run as Administrator' option should not be used for the installation of the S32 Design Studio.
As mentioned in the S32DS installation guide:
Please check installation guide for the step by step guide :
If you are getting an error on Windows permissions, then you likely do not have the necessary permissions to install. Please contact your IT department to for their assistance.
Please let us know if you were resolve the issue, upon tyring accordingly.
Thank you. Kind regards.
- Mehul Patel
4,421件の閲覧回数
StrayCat
Hi Mehul,
Thank you for your reply. There's actually User Account Control enabled on my laptop. Software is installed with assistance of my IT colleague and permissions are elevated during installation as described in installation guide.
