Relocating Data into RAM
yujinsheng
Fresh Out Contributor
I want to fix the variable in the function to the fixed RAM address, but it does not clear after reset, but it has not been realized. Could you provide an example or method
Using hardware: s32k116
lukaszadrapa
please take a look at this thread:
https://community.nxp.com/thread/479342
Lukas
yujinsheng
thanks for your reply!
  • I want to set all of the.c file variables to a fixed segment
    Your method is to solve a variable that I have set successfully
lukaszadrapa
In this case, see please this one:
define linker section for entire file
or
https://community.nxp.com/thread/331043
Lukas
