Problem to install lauterbach trace32 debugger plug-in into S32 Design Studio
3,989件の閲覧回数
Jang123
i tried to install lauterbach Trace32 debugger plug-in into S32 Design Studio for Power Architecture Version 2017.R1.
However, i unable to read repository at http://www.lauterbach.com/eclipse
if i used S32 Design Studio for Power Architecture Version 2.1 instead of S32 Design Studio for Power Architecture Version 2017.R1, i can install lauterbach Trace32 debugger.
but i have to used S32 Design Studio for Power Architecture Version 2017.R1
Can I get some advice to resolve this problem??
8 返答(返信)
3,984件の閲覧回数
jiri_kral
is there some error message when you try to install Lauterbach plugin?
3,969件の閲覧回数
Jang123
If I used ver.2017 R1, I receive follow error
If I used Ver 2.1 I can install them like follow image
i don’t know diffrence between ver 2017 and ver 2.1
3,743件の閲覧回数
jiri_kral
sorry for delay. The S32DS v2017.R1 (based on Eclipse v4.6) is quite old and it is possible that it is no more supported by Lauterbach plugin. Please try to contact Lauterbach support.
3,980件の閲覧回数
Jang123
IMG_0258.jpegi received error message "org.eclipse.equinox.p2.core.ProvisionException\\unable to read repository at http://www.lauterbach.com/eclipse/content.xml." when i try to install them
3,622件の閲覧回数
krishnaraomane1
I am also seeing same problem when trying to add plugins for lauterbach even with nxp Websites observed same errors snapshots are as follows
3,607件の閲覧回数
jiri_kral
this issue is probably caused by your company IT/Network policy. Please contact your local IT.
2,915件の閲覧回数
SARATHI_22
hi Jiri,
can i get the plugin as a installable zip package.
thanks
2,909件の閲覧回数
jiri_kral
please contact Lauterbach support. It is Lauterbach plugin for Eclipse.
