PE-ERROR: Warning. Can't read memory while part is running
3,256 次查看
459021854
Hi experts:
I have a problem with debugging. please help me, need your help!
when programm hits the breakpoints. the program halts, however, when to see memory value or Expressions, the console window always show following prompts, so my memory and Expression can not be read successfully. what wrong with my debugger configurations? or any solutions? pleasepastedImage_1.png
标记 (3)
3,213 次查看
jiri_kral
can you please share full output from debugger console?
Jiri
