Multiple FlexCAN Configurations in ConfigTools?
1,415 次查看
tsweaver
I'm in the process of migrating a project from S32DS v2.2 with Processor Expert to S32DS v3.5 with Config Tools.  In PE, you can define multiple CAN Configurations.  For example, one for CAN at 250 Kbps and one at 500 Kbps.  I actually have 8 CAN configurations defined in PE.  In the Peripherals Tool (Config Tools), I'm not seeing a way to define more than one configuration per CAN instance.  Am I missing something? Do I just have to create my own config structs?
1,389 次查看
PetrS
yes, in Config tool single config struct can be defined. If needed you can create own in your code.
BR, Petr
1,390 次查看
PetrS
BR, Petr
