MCAL Data Mapping fails
liyongfeng
#define MCU_START_SEC_VAR_INIT_UNSPECIFIED
#include "Mcu_MemMap.h"
Mcu_StatusType Mcu_eStatus = MCU_UNINIT;
#define MCU_STOP_SEC_VAR_INIT_UNSPECIFIED
After bulid, the data fails to map to the .macl_data section:
.mcal_data.Mcu_eStatus
0x204201dd 0x1 load address 0x0040eb0d
Mapping to the .macl_data section is only achievable when __attribute__((section(".mcal_data"))) is used.
The content of the ld file is as follows:
.sram_data : AT(__sram_data_rom)
. = ALIGN(4);
__sram_data_begin__ = .;
. = ALIGN(4);
*(.ramcode)
. = ALIGN(4);
*(.data)
*(.data*)
. = ALIGN(4);
*(.mcal_data)
. = ALIGN(4);
__sram_data_end__ = .;
} > int_sram_c0
I can map correctly using *(.mcal_data*); is this method suitable?
liyongfeng
Understood. The (-fdata-sections) option is enabled by default when a new project is created in D32DS. Alternatively, this may be attributed to my lack of knowledge regarding compiler commands.
liyongfeng
liyongfeng
liyongfeng_0-1767580146080.pngCould you help me figure out where the problem is?
RTD : SW32K3_S32M27x_RTD_R21-11_6.0.0_QLP04
lukaszadrapa
Could you try following?
Add this to main.c or any other c file:
Then do a right click in this *.c file and select "Preprocess Selected File(s)".
You should get something like this for the definition above:
# 1 "c:\\nxp\\s32ds.3.6.2\\s32ds\\software\\platformsdk_s32k3\\rtd\\basenxp_ts_t40d34m60i0r0\\include\\mcu_memmap.h" 1
# 57 "c:\\nxp\\s32ds.3.6.2\\s32ds\\software\\platformsdk_s32k3\\rtd\\basenxp_ts_t40d34m60i0r0\\include\\mcu_memmap.h"
#define MCU_MEMMAP_VENDOR_ID 43
#define MCU_MEMMAP_AR_RELEASE_MAJOR_VERSION 4
#define MCU_MEMMAP_AR_RELEASE_MINOR_VERSION 7
#define MCU_MEMMAP_AR_RELEASE_REVISION_VERSION 0
#define MCU_MEMMAP_SW_MAJOR_VERSION 6
#define MCU_MEMMAP_SW_MINOR_VERSION 0
#define MCU_MEMMAP_SW_PATCH_VERSION 0
# 81 "c:\\nxp\\s32ds.3.6.2\\s32ds\\software\\platformsdk_s32k3\\rtd\\basenxp_ts_t40d34m60i0r0\\include\\mcu_memmap.h"
#define MEMMAP_ERROR
# 7329 "c:\\nxp\\s32ds.3.6.2\\s32ds\\software\\platformsdk_s32k3\\rtd\\basenxp_ts_t40d34m60i0r0\\include\\mcu_memmap.h"
#undef MCU_START_SEC_VAR_INIT_UNSPECIFIED
#define ENTERED_MCU_START_SEC_VAR_INIT_UNSPECIFIED
#define MEMMAP_MATCH_ERROR
# 7341 "c:\\nxp\\s32ds.3.6.2\\s32ds\\software\\platformsdk_s32k3\\rtd\\basenxp_ts_t40d34m60i0r0\\include\\mcu_memmap.h"
#undef MEMMAP_ERROR
#pragma GCC section data ".mcal_data"
#pragma GCC section bss ".mcal_bss"
# 42 "..\\src\\main.c" 2
# 7351 "c:\\nxp\\s32ds.3.6.2\\s32ds\\software\\platformsdk_s32k3\\rtd\\basenxp_ts_t40d34m60i0r0\\include\\mcu_memmap.h"
#undef ENTERED_MCU_START_SEC_VAR_INIT_UNSPECIFIED
#undef MEMMAP_MATCH_ERROR
#undef MCU_STOP_SEC_VAR_INIT_UNSPECIFIED
Please send me this output.
liyongfeng
Hi @lukaszadrapa ,
This is the information generated by using the variable Test_Mcu_eStatus in my main.c file.
lukaszadrapa
Hi @liyongfeng
Which RTD is used? I can't see such issue on my side, MCU_START_SEC_VAR_INIT_UNSPECIFIED is working for me. Did you get any warnings when building the project?
Lukas
%3CLINGO-SUB%20id%3D%22lingo-sub-2267626%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMCAL%20Data%20Mapping%20fails%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2267626%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%23define%20MCU_START_SEC_VAR_INIT_UNSPECIFIED%3C%2FP%3E%3CP%3E%23include%20%22Mcu_MemMap.h%22%3C%2FP%3E%3CP%3EMcu_StatusType%20Mcu_eStatus%20%3D%20MCU_UNINIT%3B%3C%2FP%3E%3CP%3E%23define%20MCU_STOP_SEC_VAR_INIT_UNSPECIFIED%3C%2FP%3E%3CP%3E%23include%20%22Mcu_MemMap.h%22%3C%2FP%3E%3CP%3E%3CSPAN%3EAfter%20bulid%2C%20the%20data%20fails%20to%20map%20to%20the%26nbsp%3B%3C%2FSPAN%3E.macl_data%3CSPAN%3E%26nbsp%3Bsection%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E.mcal_data.Mcu_eStatus%3CBR%20%2F%3E0x204201dd%200x1%20load%20address%200x0040eb0d%3C%2FP%3E%3CP%3E%3CSPAN%3EMapping%20to%20the%26nbsp%3B%3C%2FSPAN%3E.macl_data%3CSPAN%3E%26nbsp%3Bsection%20is%20only%20achievable%20when%20%3C%2FSPAN%3E__attribute__((section(%22.mcal_data%22)))%3CSPAN%3E%26nbsp%3Bis%20used.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EThe%20content%20of%20the%20ld%20file%20is%20as%20follows%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CP%3E.sram_data%20%3A%20%3CSPAN%3EAT%3C%2FSPAN%3E(__sram_data_rom)%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3E.%20%3D%20%3CSPAN%3EALIGN%3C%2FSPAN%3E(4)%3B%3C%2FP%3E%3CP%3E__sram_data_begin__%20%3D%20.%3B%3C%2FP%3E%3CP%3E.%20%3D%20%3CSPAN%3EALIGN%3C%2FSPAN%3E(4)%3B%3C%2FP%3E%3CP%3E*(.ramcode)%3C%2FP%3E%3CP%3E.%20%3D%20%3CSPAN%3EALIGN%3C%2FSPAN%3E(4)%3B%3C%2FP%3E%3CP%3E*(.data)%3C%2FP%3E%3CP%3E*(.data*)%3C%2FP%3E%3CP%3E.%20%3D%20%3CSPAN%3EALIGN%3C%2FSPAN%3E(4)%3B%3C%2FP%3E%3CP%3E*(.mcal_data)%3C%2FP%3E%3CP%3E.%20%3D%20%3CSPAN%3EALIGN%3C%2FSPAN%3E(4)%3B%3C%2FP%3E%3CP%3E__sram_data_end__%20%3D%20.%3B%3C%2FP%3E%3CP%3E%7D%20%26gt%3B%20int_sram_c0%3C%2FP%3E%3CP%3E%3CSPAN%3EI%20can%20map%20correctly%20using%26nbsp%3B%3C%2FSPAN%3E*(.mcal_data*)%3CSPAN%3E%3B%20is%20this%20method%20suitable%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2270547%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCAL%20Data%20Mapping%20fails%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2270547%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F184101%22%20target%3D%22_blank%22%3E%40liyongfeng%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EWhich%20RTD%20is%20used%3F%20I%20can't%20see%20such%20issue%20on%20my%20side%2C%26nbsp%3BMCU_START_SEC_VAR_INIT_UNSPECIFIED%20is%20working%20for%20me.%20Did%20you%20get%20any%20warnings%20when%20building%20the%20project%3F%3C%2FP%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E
