Import project dependencies from the command line
113 次查看
Greavesinator85
I am trying to set up a command line build, and thanks to the documentation I have been successful.
To improve this, I would like to not commit my dependencies, such as stacks/lwip/ gptp_stack/ and FreeRTOS/ to git.
For this to work, I need to import these dependencies from the command line, replicating one of the two steps that "Update Code" does in the S32DS GUI.
I've looked at manual copies, but it seems it is not this straight forward, especially for RTD/
Attached is my script, which works but does not import the dependencies.
Pasting here since I can't attach a powershell script!
param(
    [switch]$SkipMex = $false,
    [switch]$Clean = $false,
    [string]$S32DSRoot = ""
# Auto-detect project root (script can be in project root or scripts subdirectory)
$ScriptDir = Split-Path -Parent $MyInvocation.MyCommand.Path
if (Test-Path "$ScriptDir\.cproject") {
    $ProjectRoot = $ScriptDir
} elseif (Test-Path "$ScriptDir\..\.cproject") {
    $ProjectRoot = Resolve-Path "$ScriptDir\.."
} else {
    throw "Cannot find project root (no .cproject found)"
# S32DS installation path (check parameter, then environment variable, then default)
if (-not $S32DSRoot) {
    if ($env:S32DS_ROOT) {
        $S32DSRoot = $env:S32DS_ROOT
    } else {
        $S32DSRoot = "C:\NXP\S32DS.3.6.4"
if (-not (Test-Path "$S32DSRoot\eclipse\s32dsc.exe")) {
    throw "S32DS not found at: $S32DSRoot`nSet S32DSRoot parameter or S32DS_ROOT environment variable"
# Workspace directory (must be OUTSIDE project to avoid recursive scanning)
$ProjectName = Split-Path -Leaf $ProjectRoot
$WorkspaceDir = Join-Path (Split-Path -Parent $ProjectRoot) ".s32ds_workspace_$ProjectName"
# Build output directory
$BuildOutputDir = "$ProjectRoot\Debug_FLASH"
if (-not (Test-Path $BuildOutputDir)) {
    New-Item -ItemType Directory -Path $BuildOutputDir -Force | Out-Null
# Set environment variables
$env:RTD_PATH = "$S32DSRoot\S32DS\software\PlatformSDK_S32K3"
$env:BASE_PLATFORMSDK_S32K3 = "$S32DSRoot\S32DS\software\PlatformSDK_S32K3\RTD\BaseNXP_TS_T40D34M60I0R0"
$env:PLATFORM_PLATFORMSDK_S32K3 = "$S32DSRoot\S32DS\software\PlatformSDK_S32K3\RTD\Platform_TS_T40D34M60I0R0"
$env:PlatformSDK_S32K3 = "$S32DSRoot\S32DS\software\PlatformSDK_S32K3"
Write-Host "`n============================================================"
Write-Host "  S32DS Headless Build Script"
Write-Host "============================================================"
Write-Host "Project:   $ProjectRoot"
Write-Host "Workspace: $WorkspaceDir"
Write-Host "Skip MEX:  $SkipMex"
Write-Host "Clean:     $Clean"
Write-Host "============================================================`n"
Push-Location "$S32DSRoot\eclipse"
try {
    # Step 1: MEX Code Generation
    if (-not $SkipMex) {
        Write-Host "[1/3] Running MEX code generation..."
        # Delete auto-generated S32K358.mex if it exists
        $autoMexPath = "$ProjectRoot\S32K358.mex"
        if (Test-Path $autoMexPath) {
            Write-Host "  --> Removing auto-generated S32K358.mex"
            Remove-Item $autoMexPath -Force
        $mexArgs = @(
            '-noSplash'
            '-application', 'com.nxp.swtools.framework.application'
            '--launcher.suppressErrors'
            '--launcher.ini', '.\s32ds.ini'
            '-HeadlessTool', 'Peripherals'
            '-data', $WorkspaceDir
            '-SDKPath', "$S32DSRoot\S32DS\software\PlatformSDK_S32K3"
            '-Load', "$ProjectRoot\dag_tactile_agg_fw.mex"
            '-ExportAll', $ProjectRoot
        Write-Host "  --> Running MEX tool..."
        & .\s32dsc.exe $mexArgs 2>&1 | Tee-Object -FilePath "$BuildOutputDir\mex_generation.log" | ForEach-Object {
            if ($_ -match "Processing|Generating|ERROR|WARNING|Finished") {
                Write-Host "      $_"
        # Delete S32K358.mex again if it was created during generation
        # Move HTML report to Debug_FLASH if it exists
        $htmlReport = "$ProjectRoot\html_report_Peripherals"
        if (Test-Path $htmlReport) {
            $htmlReportDest = "$BuildOutputDir\html_report_Peripherals"
            if (Test-Path $htmlReportDest) {
                Remove-Item $htmlReportDest -Recurse -Force
            Move-Item $htmlReport $htmlReportDest -Force
            Write-Host "  --> Moved html_report_Peripherals to Debug_FLASH"
        Write-Host "  [OK] MEX generation completed (log: Debug_FLASH\mex_generation.log)"
    } else {
        Write-Host "[1/3] Skipping MEX code generation"
    # Step 2: Import project
    Write-Host "`n[2/3] Ensuring project is imported..."
    $projectMetadata = "$WorkspaceDir\.metadata\.plugins\org.eclipse.core.resources\.projects\dag_tactile_agg_fw"
    if (-not (Test-Path $projectMetadata)) {
        Write-Host "  --> Importing project into workspace..."
        $importArgs = @(
            '-noSplash'
            '-application', 'org.eclipse.cdt.managedbuilder.core.headlessbuild'
            '-import', $ProjectRoot
        Write-Host "  --> Importing into workspace..."
        & .\s32dsc.exe $importArgs 2>&1 | Tee-Object -FilePath "$BuildOutputDir\import.log" | ForEach-Object {
            if ($_ -match "Importing|Project|ERROR|WARNING") {
                Write-Host "      $_"
        if ($LASTEXITCODE -ne 0) {
            Write-Host "  [ERROR] Import failed with exit code $LASTEXITCODE"
            Write-Host "  Check Debug_FLASH\import.log for details"
            Write-Host "`nLast 20 lines of import log:"
            Get-Content "$BuildOutputDir\import.log" -Tail 20 | ForEach-Object { Write-Host "    $_" }
            throw "Project import failed"
        Write-Host "  [OK] Project imported"
        # Run prebuild script (modifies .cproject, needs to run after import)
        Write-Host "  --> Running prebuild script..."
        $prebuildScript = "$ProjectRoot\scripts\prebuild.py"
        if (Test-Path $prebuildScript) {
            Push-Location $ProjectRoot
            & python $prebuildScript
            Pop-Location
            Write-Host "  [OK] Prebuild completed"
        } else {
            Write-Host "  [WARNING] Prebuild script not found: $prebuildScript"
    } else {
        Write-Host "  [OK] Project already imported"
    # Step 3: Build
    Write-Host "`n[3/3] Running build..."
    $buildType = if ($Clean) { "-cleanBuild" } else { "-build" }
    $buildTypeLabel = if ($Clean) { "Clean build" } else { "Incremental build" }
    Write-Host "  --> $buildTypeLabel starting...`n"
    $buildArgs = @(
        '-noSplash'
        $buildType, 'dag_tactile_agg_fw/Debug_FLASH'
    $buildStart = Get-Date
    $buildLogPath = "$BuildOutputDir\build_output.log"
    # Run build with real-time output
    & .\s32dsc.exe $buildArgs 2>&1 | Tee-Object -FilePath $buildLogPath | ForEach-Object {
        # Show build progress lines
        if ($_ -match "^\[|Building|Compiling|Linking|Finished|error|warning") {
            Write-Host $_
    $buildDuration = (Get-Date) - $buildStart
    # Check build result more accurately
    $buildContent = Get-Content $buildLogPath -Raw
    $buildFailed = $buildContent -match "Build Failed" -or $buildContent -match "\d+ error"
    $errorCount = if ($buildContent -match "(\d+) error") { [int]$matches[1] } else { 0 }
    if ($buildFailed -and $errorCount -gt 0) {
        Write-Host "  [ERROR] BUILD FAILED ($errorCount errors)"
        Write-Host "`nError details:"
        Get-Content $buildLogPath | Select-String -Pattern "error:" | Select-Object -First 10 | ForEach-Object {
            Write-Host "  $_"
        Write-Host "`nFull build output: Debug_FLASH\build_output.log"
        Write-Host "Duration: $([math]::Round($buildDuration.TotalSeconds, 1)) seconds`n"
        exit 1
    } else {
        $elfPath = "$ProjectRoot\Debug_FLASH\dag_tactile_agg_fw.elf"
        if (Test-Path $elfPath) {
            $elfInfo = Get-Item $elfPath
            Write-Host "  [OK] BUILD SUCCESSFUL"
            Write-Host "`nOutput:"
            Write-Host "  ELF file: $elfPath"
            Write-Host "  Size:     $([math]::Round($elfInfo.Length/1KB, 2)) KB"
            Write-Host "  Modified: $($elfInfo.LastWriteTime)"
            Write-Host "  Duration: $([math]::Round($buildDuration.TotalSeconds, 1)) seconds`n"
            exit 0
        } else {
            Write-Host "  [WARNING] BUILD COMPLETED (status unclear)"
            Write-Host "`nNo errors detected but ELF file not found."
            Write-Host "Check Debug_FLASH\build_output.log for details.`n"
            exit 0
catch {
    Write-Host "`nScript failed: $_"
    Write-Host $_.ScriptStackTrace
    exit 1
finally {
    Pop-Location
0 回复数
%3CLINGO-SUB%20id%3D%22lingo-sub-2263791%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BB%8E%E5%91%BD%E4%BB%A4%E8%A1%8C%E5%AF%BC%E5%85%A5%E9%A1%B9%E7%9B%AE%E4%BE%9D%E8%B5%96%E9%A1%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2263791%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E8%AE%BE%E7%BD%AE%E5%91%BD%E4%BB%A4%E8%A1%8C%E7%89%88%E6%9C%AC%EF%BC%8C%E5%A4%9A%E4%BA%8F%E4%BA%86%E6%96%87%E6%A1%A3%EF%BC%8C%E6%88%91%E6%89%8D%E6%88%90%E5%8A%9F%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%BA%E4%BA%86%E6%94%B9%E8%BF%9B%E8%BF%99%E4%B8%80%E7%82%B9%EF%BC%8C%E6%88%91%E5%B8%8C%E6%9C%9B%E4%B8%8D%E8%A6%81%E5%B0%86%E6%88%91%E7%9A%84%E4%BE%9D%E8%B5%96%E9%A1%B9%EF%BC%88%E5%A6%82%20stacks%2Flwip%2F%20gptp_stack%2F%20%E5%92%8C%20FreeRTOS%2F%EF%BC%89%E6%8F%90%E4%BA%A4%E5%88%B0%20git%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%BA%E6%AD%A4%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%E4%BB%8E%E5%91%BD%E4%BB%A4%E8%A1%8C%E5%AF%BC%E5%85%A5%E8%BF%99%E4%BA%9B%E4%BE%9D%E8%B5%96%E9%A1%B9%EF%BC%8C%E5%A4%8D%E5%88%B6%22%E6%9B%B4%E6%96%B0%E4%BB%A3%E7%A0%81%22%20%E5%9C%A8%20S32DS%20GUI%20%E4%B8%AD%E6%89%A7%E8%A1%8C%E7%9A%84%E4%B8%A4%E4%B8%AA%E6%AD%A5%E9%AA%A4%E4%B9%8B%E4%B8%80%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%9F%A5%E7%9C%8B%E4%BA%86%E6%89%8B%E5%8A%A8%E6%8B%B7%E8%B4%9D%EF%BC%8C%E4%BD%86%E4%BC%BC%E4%B9%8E%E5%B9%B6%E4%B8%8D%E9%82%A3%E4%B9%88%E7%AE%80%E5%8D%95%EF%BC%8C%E5%B0%A4%E5%85%B6%E6%98%AF%20RTD%2F......%E3%80%82%3C%2FP%3E%3CP%3E%E9%99%84%E4%B8%8A%E6%88%91%E7%9A%84%E8%84%9A%E6%9C%AC%EF%BC%8C%E5%AE%83%E5%8F%AF%E4%BB%A5%E8%BF%90%E8%A1%8C%EF%BC%8C%E4%BD%86%E4%B8%8D%E8%83%BD%E5%AF%BC%E5%85%A5%E4%BE%9D%E8%B5%96%E9%A1%B9%E3%80%82%3C%2FP%3E%3CP%3E%E7%94%B1%E4%BA%8E%E6%88%91%E6%97%A0%E6%B3%95%E9%99%84%E4%B8%8A%20powershell%20%E8%84%9A%E6%9C%AC%EF%BC%8C%E6%89%80%E4%BB%A5%E5%9C%A8%E6%AD%A4%E7%B2%98%E8%B4%B4%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eparam(%0A%20%20%20%20%5Bswitch%5D%24SkipMex%20%3D%20%24false%2C%0A%20%20%20%20%5Bswitch%5D%24Clean%20%3D%20%24false%2C%0A%20%20%20%20%5Bstring%5D%24S32DSRoot%20%3D%20%22%22%0A)%0A%0A%23%20Auto-detect%20project%20root%20(script%20can%20be%20in%20project%20root%20or%20scripts%20subdirectory)%0A%24ScriptDir%20%3D%20Split-Path%20-Parent%20%24MyInvocation.MyCommand.Path%0Aif%20(Test-Path%20%22%24ScriptDir%5C.cproject%22)%20%7B%0A%20%20%20%20%24ProjectRoot%20%3D%20%24ScriptDir%0A%7D%20elseif%20(Test-Path%20%22%24ScriptDir%5C..%5C.cproject%22)%20%7B%0A%20%20%20%20%24ProjectRoot%20%3D%20Resolve-Path%20%22%24ScriptDir%5C..%22%0A%7D%20else%20%7B%0A%20%20%20%20throw%20%22Cannot%20find%20project%20root%20(no%20.cproject%20found)%22%0A%7D%0A%0A%23%20S32DS%20installation%20path%20(check%20parameter%2C%20then%20environment%20variable%2C%20then%20default)%0Aif%20(-not%20%24S32DSRoot)%20%7B%0A%20%20%20%20if%20(%24env%3AS32DS_ROOT)%20%7B%0A%20%20%20%20%20%20%20%20%24S32DSRoot%20%3D%20%24env%3AS32DS_ROOT%0A%20%20%20%20%7D%20else%20%7B%0A%20%20%20%20%20%20%20%20%24S32DSRoot%20%3D%20%22C%3A%5CNXP%5CS32DS.3.6.4%22%0A%20%20%20%20%7D%0A%7D%0A%0Aif%20(-not%20(Test-Path%20%22%24S32DSRoot%5Ceclipse%5Cs32dsc.exe%22))%20%7B%0A%20%20%20%20throw%20%22S32DS%20not%20found%20at%3A%20%24S32DSRoot%60nSet%20S32DSRoot%20parameter%20or%20S32DS_ROOT%20environment%20variable%22%0A%7D%0A%0A%23%20Workspace%20directory%20(must%20be%20OUTSIDE%20project%20to%20avoid%20recursive%20scanning)%0A%24ProjectName%20%3D%20Split-Path%20-Leaf%20%24ProjectRoot%0A%24WorkspaceDir%20%3D%20Join-Path%20(Split-Path%20-Parent%20%24ProjectRoot)%20%22.s32ds_workspace_%24ProjectName%22%0A%0A%23%20Build%20output%20directory%0A%24BuildOutputDir%20%3D%20%22%24ProjectRoot%5CDebug_FLASH%22%0Aif%20(-not%20(Test-Path%20%24BuildOutputDir))%20%7B%0A%20%20%20%20New-Item%20-ItemType%20Directory%20-Path%20%24BuildOutputDir%20-Force%20%7C%20Out-Null%0A%7D%0A%0A%23%20Set%20environment%20variables%0A%24env%3ARTD_PATH%20%3D%20%22%24S32DSRoot%5CS32DS%5Csoftware%5CPlatformSDK_S32K3%22%0A%24env%3ABASE_PLATFORMSDK_S32K3%20%3D%20%22%24S32DSRoot%5CS32DS%5Csoftware%5CPlatformSDK_S32K3%5CRTD%5CBaseNXP_TS_T40D34M60I0R0%22%0A%24env%3APLATFORM_PLATFORMSDK_S32K3%20%3D%20%22%24S32DSRoot%5CS32DS%5Csoftware%5CPlatformSDK_S32K3%5CRTD%5CPlatform_TS_T40D34M60I0R0%22%0A%24env%3APlatformSDK_S32K3%20%3D%20%22%24S32DSRoot%5CS32DS%5Csoftware%5CPlatformSDK_S32K3%22%0A%0AWrite-Host%20%22%60n%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%22%0AWrite-Host%20%22%20%20S32DS%20Headless%20Build%20Script%22%0AWrite-Host%20%22%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%22%0AWrite-Host%20%22Project%3A%20%20%20%24ProjectRoot%22%0AWrite-Host%20%22Workspace%3A%20%24WorkspaceDir%22%0AWrite-Host%20%22Skip%20MEX%3A%20%20%24SkipMex%22%0AWrite-Host%20%22Clean%3A%20%20%20%20%20%24Clean%22%0AWrite-Host%20%22%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%60n%22%0A%0APush-Location%20%22%24S32DSRoot%5Ceclipse%22%0A%0Atry%20%7B%0A%20%20%20%20%23%20Step%201%3A%20MEX%20Code%20Generation%0A%20%20%20%20if%20(-not%20%24SkipMex)%20%7B%0A%20%20%20%20%20%20%20%20Write-Host%20%22%5B1%2F3%5D%20Running%20MEX%20code%20generation...%22%0A%0A%20%20%20%20%20%20%20%20%23%20Delete%20auto-generated%20S32K358.mex%20if%20it%20exists%0A%20%20%20%20%20%20%20%20%24autoMexPath%20%3D%20%22%24ProjectRoot%5CS32K358.mex%22%0A%20%20%20%20%20%20%20%20if%20(Test-Path%20%24autoMexPath)%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20Write-Host%20%22%20%20--%26gt%3B%20Removing%20auto-generated%20S32K358.mex%22%0A%20%20%20%20%20%20%20%20%20%20%20%20Remove-Item%20%24autoMexPath%20-Force%0A%20%20%20%20%20%20%20%20%7D%0A%0A%20%20%20%20%20%20%20%20%24mexArgs%20%3D%20%40(%0A%20%20%20%20%20%20%20%20%20%20%20%20'-noSplash'%0A%20%20%20%20%20%20%20%20%20%20%20%20'-application'%2C%20'com.nxp.swtools.framework.application'%0A%20%20%20%20%20%20%20%20%20%20%20%20'--launcher.suppressErrors'%0A%20%20%20%20%20%20%20%20%20%20%20%20'--launcher.ini'%2C%20'.%5Cs32ds.ini'%0A%20%20%20%20%20%20%20%20%20%20%20%20'-HeadlessTool'%2C%20'Peripherals'%0A%20%20%20%20%20%20%20%20%20%20%20%20'-data'%2C%20%24WorkspaceDir%0A%20%20%20%20%20%20%20%20%20%20%20%20'-SDKPath'%2C%20%22%24S32DSRoot%5CS32DS%5Csoftware%5CPlatformSDK_S32K3%22%0A%20%20%20%20%20%20%20%20%20%20%20%20'-Load'%2C%20%22%24ProjectRoot%5Cdag_tactile_agg_fw.mex%22%0A%20%20%20%20%20%20%20%20%20%20%20%20'-ExportAll'%2C%20%24ProjectRoot%0A%20%20%20%20%20%20%20%20)%0A%0A%20%20%20%20%20%20%20%20Write-Host%20%22%20%20--%26gt%3B%20Running%20MEX%20tool...%22%0A%20%20%20%20%20%20%20%20%26amp%3B%20.%5Cs32dsc.exe%20%24mexArgs%202%26gt%3B%26amp%3B1%20%7C%20Tee-Object%20-FilePath%20%22%24BuildOutputDir%5Cmex_generation.log%22%20%7C%20ForEach-Object%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20if%20(%24_%20-match%20%22Processing%7CGenerating%7CERROR%7CWARNING%7CFinished%22)%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Write-Host%20%22%20%20%20%20%20%20%24_%22%0A%20%20%20%20%20%20%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20%20%20%7D%0A%0A%20%20%20%20%20%20%20%20%23%20Delete%20S32K358.mex%20again%20if%20it%20was%20created%20during%20generation%0A%20%20%20%20%20%20%20%20if%20(Test-Path%20%24autoMexPath)%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20Write-Host%20%22%20%20--%26gt%3B%20Removing%20auto-generated%20S32K358.mex%22%0A%20%20%20%20%20%20%20%20%20%20%20%20Remove-Item%20%24autoMexPath%20-Force%0A%20%20%20%20%20%20%20%20%7D%0A%0A%20%20%20%20%20%20%20%20%23%20Move%20HTML%20report%20to%20Debug_FLASH%20if%20it%20exists%0A%20%20%20%20%20%20%20%20%24htmlReport%20%3D%20%22%24ProjectRoot%5Chtml_report_Peripherals%22%0A%20%20%20%20%20%20%20%20if%20(Test-Path%20%24htmlReport)%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%24htmlReportDest%20%3D%20%22%24BuildOutputDir%5Chtml_report_Peripherals%22%0A%20%20%20%20%20%20%20%20%20%20%20%20if%20(Test-Path%20%24htmlReportDest)%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Remove-Item%20%24htmlReportDest%20-Recurse%20-Force%0A%20%20%20%20%20%20%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20%20%20%20%20%20%20Move-Item%20%24htmlReport%20%24htmlReportDest%20-Force%0A%20%20%20%20%20%20%20%20%20%20%20%20Write-Host%20%22%20%20--%26gt%3B%20Moved%20html_report_Peripherals%20to%20Debug_FLASH%22%0A%20%20%20%20%20%20%20%20%7D%0A%0A%20%20%20%20%20%20%20%20Write-Host%20%22%20%20%5BOK%5D%20MEX%20generation%20completed%20(log%3A%20Debug_FLASH%5Cmex_generation.log)%22%0A%20%20%20%20%7D%20else%20%7B%0A%20%20%20%20%20%20%20%20Write-Host%20%22%5B1%2F3%5D%20Skipping%20MEX%20code%20generation%22%0A%20%20%20%20%7D%0A%0A%20%20%20%20%23%20Step%202%3A%20Import%20project%0A%20%20%20%20Write-Host%20%22%60n%5B2%2F3%5D%20Ensuring%20project%20is%20imported...%22%0A%0A%20%20%20%20%24projectMetadata%20%3D%20%22%24WorkspaceDir%5C.metadata%5C.plugins%5Corg.eclipse.core.resources%5C.projects%5Cdag_tactile_agg_fw%22%0A%20%20%20%20if%20(-not%20(Test-Path%20%24projectMetadata))%20%7B%0A%20%20%20%20%20%20%20%20Write-Host%20%22%20%20--%26gt%3B%20Importing%20project%20into%20workspace...%22%0A%0A%20%20%20%20%20%20%20%20%24importArgs%20%3D%20%40(%0A%20%20%20%20%20%20%20%20%20%20%20%20'-noSplash'%0A%20%20%20%20%20%20%20%20%20%20%20%20'-application'%2C%20'org.eclipse.cdt.managedbuilder.core.headlessbuild'%0A%20%20%20%20%20%20%20%20%20%20%20%20'-data'%2C%20%24WorkspaceDir%0A%20%20%20%20%20%20%20%20%20%20%20%20'-import'%2C%20%24ProjectRoot%0A%20%20%20%20%20%20%20%20)%0A%0A%20%20%20%20%20%20%20%20Write-Host%20%22%20%20--%26gt%3B%20Importing%20into%20workspace...%22%0A%20%20%20%20%20%20%20%20%26amp%3B%20.%5Cs32dsc.exe%20%24importArgs%202%26gt%3B%26amp%3B1%20%7C%20Tee-Object%20-FilePath%20%22%24BuildOutputDir%5Cimport.log%22%20%7C%20ForEach-Object%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20if%20(%24_%20-match%20%22Importing%7CProject%7CERROR%7CWARNING%22)%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Write-Host%20%22%20%20%20%20%20%20%24_%22%0A%20%20%20%20%20%20%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20%20%20%7D%0A%0A%20%20%20%20%20%20%20%20if%20(%24LASTEXITCODE%20-ne%200)%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20Write-Host%20%22%20%20%5BERROR%5D%20Import%20failed%20with%20exit%20code%20%24LASTEXITCODE%22%0A%20%20%20%20%20%20%20%20%20%20%20%20Write-Host%20%22%20%20Check%20Debug_FLASH%5Cimport.log%20for%20details%22%0A%20%20%20%20%20%20%20%20%20%20%20%20Write-Host%20%22%60nLast%2020%20lines%20of%20import%20log%3A%22%0A%20%20%20%20%20%20%20%20%20%20%20%20Get-Content%20%22%24BuildOutputDir%5Cimport.log%22%20-Tail%2020%20%7C%20ForEach-Object%20%7B%20Write-Host%20%22%20%20%20%20%24_%22%20%7D%0A%20%20%20%20%20%20%20%20%20%20%20%20throw%20%22Project%20import%20failed%22%0A%20%20%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20%20%20Write-Host%20%22%20%20%5BOK%5D%20Project%20imported%22%0A%0A%20%20%20%20%20%20%20%20%23%20Run%20prebuild%20script%20(modifies%20.cproject%2C%20needs%20to%20run%20after%20import)%0A%20%20%20%20%20%20%20%20Write-Host%20%22%20%20--%26gt%3B%20Running%20prebuild%20script...%22%0A%20%20%20%20%20%20%20%20%24prebuildScript%20%3D%20%22%24ProjectRoot%5Cscripts%5Cprebuild.py%22%0A%20%20%20%20%20%20%20%20if%20(Test-Path%20%24prebuildScript)%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20Push-Location%20%24ProjectRoot%0A%20%20%20%20%20%20%20%20%20%20%20%20%26amp%3B%20python%20%24prebuildScript%0A%20%20%20%20%20%20%20%20%20%20%20%20Pop-Location%0A%20%20%20%20%20%20%20%20%20%20%20%20Write-Host%20%22%20%20%5BOK%5D%20Prebuild%20completed%22%0A%20%20%20%20%20%20%20%20%7D%20else%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20Write-Host%20%22%20%20%5BWARNING%5D%20Prebuild%20script%20not%20found%3A%20%24prebuildScript%22%0A%20%20%20%20%20%20%20%20%7D%0A%20%20%20%20%7D%20else%20%7B%0A%20%20%20%20%20%20%20%20Write-Host%20%22%20%20%5BOK%5D%20Project%20already%20imported%22%0A%20%20%20%20%7D%0A%0A%20%20%20%20%23%20Step%203%3A%20Build%0A%20%20%20%20Write-Host%20%22%60n%5B3%2F3%5D%20Running%20build...%22%0A%0A%20%20%20%20%24buildType%20%3D%20if%20(%24Clean)%20%7B%20%22-cleanBuild%22%20%7D%20else%20%7B%20%22-build%22%20%7D%0A%20%20%20%20%24buildTypeLabel%20%3D%20if%20(%24Clean)%20%7B%20%22Clean%20build%22%20%7D%20else%20%7B%20%22Incremental%20build%22%20%7D%0A%0A%20%20%20%20Write-Host%20%22%20%20--%26gt%3B%20%24buildTypeLabel%20starting...%60n%22%0A%0A%20%20%20%20%24buildArgs%20%3D%20%40(%0A%20%20%20%20%20%20%20%20'-noSplash'%0A%20%20%20%20%20%20%20%20'-application'%2C%20'org.eclipse.cdt.managedbuilder.core.headlessbuild'%0A%20%20%20%20%20%20%20%20'-data'%2C%20%24WorkspaceDir%0A%20%20%20%20%20%20%20%20%24buildType%2C%20'dag_tactile_agg_fw%2FDebug_FLASH'%0A%20%20%20%20)%0A%0A%20%20%20%20%24buildStart%20%3D%20Get-Date%0A%20%20%20%20%24buildLogPath%20%3D%20%22%24BuildOutputDir%5Cbuild_output.log%22%0A%0A%20%20%20%20%23%20Run%20build%20with%20real-time%20output%0A%20%20%20%20%26amp%3B%20.%5Cs32dsc.exe%20%24buildArgs%202%26gt%3B%26amp%3B1%20%7C%20Tee-Object%20-FilePath%20%24buildLogPath%20%7C%20ForEach-Object%20%7B%0A%20%20%20%20%20%20%20%20%23%20Show%20build%20progress%20lines%0A%20%20%20%20%20%20%20%20if%20(%24_%20-match%20%22%5E%5C%5B%7CBuilding%7CCompiling%7CLinking%7CFinished%7Cerror%7Cwarning%22)%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20Write-Host%20%24_%0A%20%20%20%20%20%20%20%20%7D%0A%20%20%20%20%7D%0A%0A%20%20%20%20%24buildDuration%20%3D%20(Get-Date)%20-%20%24buildStart%0A%0A%20%20%20%20%23%20Check%20build%20result%20more%20accurately%0A%20%20%20%20%24buildContent%20%3D%20Get-Content%20%24buildLogPath%20-Raw%0A%20%20%20%20%24buildFailed%20%3D%20%24buildContent%20-match%20%22Build%20Failed%22%20-or%20%24buildContent%20-match%20%22%5Cd%2B%20error%22%0A%20%20%20%20%24errorCount%20%3D%20if%20(%24buildContent%20-match%20%22(%5Cd%2B)%20error%22)%20%7B%20%5Bint%5D%24matches%5B1%5D%20%7D%20else%20%7B%200%20%7D%0A%0A%20%20%20%20Write-Host%20%22%60n%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%22%0A%20%20%20%20if%20(%24buildFailed%20-and%20%24errorCount%20-gt%200)%20%7B%0A%20%20%20%20%20%20%20%20Write-Host%20%22%20%20%5BERROR%5D%20BUILD%20FAILED%20(%24errorCount%20errors)%22%0A%20%20%20%20%20%20%20%20Write-Host%20%22%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%22%0A%20%20%20%20%20%20%20%20Write-Host%20%22%60nError%20details%3A%22%0A%20%20%20%20%20%20%20%20Get-Content%20%24buildLogPath%20%7C%20Select-String%20-Pattern%20%22error%3A%22%20%7C%20Select-Object%20-First%2010%20%7C%20ForEach-Object%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20Write-Host%20%22%20%20%24_%22%0A%20%20%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20%20%20Write-Host%20%22%60nFull%20build%20output%3A%20Debug_FLASH%5Cbuild_output.log%22%0A%20%20%20%20%20%20%20%20Write-Host%20%22Duration%3A%20%24(%5Bmath%5D%3A%3ARound(%24buildDuration.TotalSeconds%2C%201))%20seconds%60n%22%0A%20%20%20%20%20%20%20%20exit%201%0A%20%20%20%20%7D%20else%20%7B%0A%20%20%20%20%20%20%20%20%24elfPath%20%3D%20%22%24ProjectRoot%5CDebug_FLASH%5Cdag_tactile_agg_fw.elf%22%0A%20%20%20%20%20%20%20%20if%20(Test-Path%20%24elfPath)%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%24elfInfo%20%3D%20Get-Item%20%24elfPath%0A%20%20%20%20%20%20%20%20%20%20%20%20Write-Host%20%22%20%20%5BOK%5D%20BUILD%20SUCCESSFUL%22%0A%20%20%20%20%20%20%20%20%20%20%20%20Write-Host%20%22%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%22%0A%20%20%20%20%20%20%20%20%20%20%20%20Write-Host%20%22%60nOutput%3A%22%0A%20%20%20%20%20%20%20%20%20%20%20%20Write-Host%20%22%20%20ELF%20file%3A%20%24elfPath%22%0A%20%20%20%20%20%20%20%20%20%20%20%20Write-Host%20%22%20%20Size%3A%20%20%20%20%20%24(%5Bmath%5D%3A%3ARound(%24elfInfo.Length%2F1KB%2C%202))%20KB%22%0A%20%20%20%20%20%20%20%20%20%20%20%20Write-Host%20%22%20%20Modified%3A%20%24(%24elfInfo.LastWriteTime)%22%0A%20%20%20%20%20%20%20%20%20%20%20%20Write-Host%20%22%20%20Duration%3A%20%24(%5Bmath%5D%3A%3ARound(%24buildDuration.TotalSeconds%2C%201))%20seconds%60n%22%0A%20%20%20%20%20%20%20%20%20%20%20%20exit%200%0A%20%20%20%20%20%20%20%20%7D%20else%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20Write-Host%20%22%20%20%5BWARNING%5D%20BUILD%20COMPLETED%20(status%20unclear)%22%0A%20%20%20%20%20%20%20%20%20%20%20%20Write-Host%20%22%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%22%0A%20%20%20%20%20%20%20%20%20%20%20%20Write-Host%20%22%60nNo%20errors%20detected%20but%20ELF%20file%20not%20found.%22%0A%20%20%20%20%20%20%20%20%20%20%20%20Write-Host%20%22Check%20Debug_FLASH%5Cbuild_output.log%20for%20details.%60n%22%0A%20%20%20%20%20%20%20%20%20%20%20%20exit%200%0A%20%20%20%20%20%20%20%20%7D%0A%20%20%20%20%7D%0A%7D%0Acatch%20%7B%0A%20%20%20%20Write-Host%20%22%60nScript%20failed%3A%20%24_%22%0A%20%20%20%20Write-Host%20%24_.ScriptStackTrace%0A%20%20%20%20exit%201%0A%7D%0Afinally%20%7B%0A%20%20%20%20Pop-Location%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
