IRQ handler in assembly
1,681 次查看
smruthi_ramesh
I have to write a custom IRQ handler for an FTM PWM overflow interrupt on the S32K148. How do I go about doing the same? Where can I find the vector table in assembly that calls the handlers defined in startup_S32k148.s?
标记 (4)
1,580 次查看
raresvasile
You can overwrite the handler using INT_SYS_InstallHandler(...).
Rares
