How to resolve undefined references to "__stack_chk_fail" in S32DS
5,525件の閲覧回数
xiongsl
I create a new application project and add the command -fstack-protector-all. The compilation fails with the following message:
undefined reference to `__stack_chk_fail'
undefined reference to `__stack_chk_guard'
S32DS projects created from Example support the -fstack-protector-all command.
I didn't find any difference in the stack protection configuration between these two projects,Can you help me with this?
MCU:FS32K146, IDE:S32DS
5 返答(返信)
5,480件の閲覧回数
jiri_kral
is into your non-example project properly linked STD C library? What version of gcc are you using?
5,475件の閲覧回数
xiongsl
I have the same configuration as you, GCC version 6.3
5,470件の閲覧回数
xiongsl
5,465件の閲覧回数
jiri_kral
I tested your project and it can be build without any issue. What's your S32DS version?
5,446件の閲覧回数
xiongsl
S32DS version is 3.4
