CPU frequency low while using S32DS to build
allenlw
before yesterday, when I am using S32DS to build a project, it only takes less than a minute, now it takes more than 3 mins.
while the S32DS is building, the CPU frequency is less than 3GHz, first I thought my computer have some hardware issues(my laptop is a new and powerful one, CPU is 14900HX), then I tried to use EB to generate code, this time the CPU frequency is higher than 5GHz, so it looks like the it is not some computer issues, more like some S32DS issues
Has anyone ever had this problem before, I need help !
jiri_kral
unfortunately nobody else met such issue. It must be related to your PC configuration.
jiri_kral
I never met such issue before, but if it was forking, I suspect that some OS update/settings prevent S32DS to use full PC resources. Please check the OS settings.
allenlw
Would you ask some of your colleagues for me? See if they met such issue before.
jiri_kral
%3CLINGO-SUB%20id%3D%22lingo-sub-1964211%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECPU%20frequency%20low%20while%20using%20S32DS%20to%20build%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1964211%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ebefore%20yesterday%2C%20when%20I%20am%20using%20S32DS%20to%20build%20a%20project%2C%20it%20only%20takes%20less%20than%20a%20minute%2C%20now%20it%20takes%20more%20than%203%20mins.%3C%2FP%3E%3CP%3Ewhile%20the%20S32DS%20is%20building%2C%20the%20CPU%20frequency%20is%20less%20than%203GHz%2C%20first%20I%20thought%20my%20computer%20have%20some%20hardware%20issues(my%20laptop%20is%20a%20new%20and%20powerful%20one%2C%20CPU%20is%2014900HX)%2C%20then%20I%20tried%20to%20use%20EB%20to%20generate%20code%2C%20this%20time%20the%20CPU%20frequency%20is%20higher%20than%205GHz%2C%20so%20it%20looks%20like%20the%20it%20is%20not%20some%20computer%20issues%2C%20more%20like%20some%20S32DS%20issues%3C%2FP%3E%3CP%3EHas%20anyone%20ever%20had%20this%20problem%20before%2C%20I%20need%20help%20!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1969774%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20CPU%20frequency%20low%20while%20using%20S32DS%20to%20build%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1969774%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%0A%3CP%3Eunfortunately%20nobody%20else%20met%20such%20issue.%20It%20must%20be%20related%20to%20your%20PC%20configuration.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1968771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20CPU%20frequency%20low%20while%20using%20S32DS%20to%20build%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1968771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWould%20you%20ask%20some%20of%20your%20colleagues%20for%20me%3F%20See%20if%20they%20met%20such%20issue%20before.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1966852%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20CPU%20frequency%20low%20while%20using%20S32DS%20to%20build%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1966852%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI%20never%20met%20such%20issue%20before%2C%20but%20if%20it%20was%20forking%2C%20I%20suspect%20that%20some%20OS%20update%2Fsettings%20prevent%20S32DS%20to%20use%20full%20PC%20resources.%20Please%20check%20the%20OS%20settings.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
