How to import KEAZ128 Lab examples project to S32D ? compile and debug
colinzou
I Fist use S32D,could not import examples project to S32D ?please help
stanish
I'd recommend you to create a new project and transfer the source files manually.
Or you can check the examples delivered with S32 Design studio (File -> New -> New S32DS project from template):
Hope it helps.
Stan
colinzou
Hi Stanislav Sliva,thank you a lot,But I already had a example in other folder.
I dont know how to import these projects.
stanish
1) go to Menu File -> Import
2) Select General\Existing Projects into Workspace
3) select directory with the examples:
Select which individual examples you would like to import (you can physically copy the projects into workspace) and press Finish button.
4) finally the projects should appear in your workspace
Hope it helps.
Stan
colinzou
   Thanks a lot
