How to get the introduction about Power ISA
4,007件の閲覧回数
flyskyr丶
   I was suggested to learn about PowerPC assembly language. So, I  browse many websites. To the end, I didn't find the most authoritative document.
   I hope you can give me directions.
demand:
   Documents about Power ISA , PowerPC ABI, PowerPC Pseudo-ops.
   Thanks!
ラベル(2)
3,846件の閲覧回数
jiri_kral
assembler directives can be found in as.pdf located in S32DS Power installation:
[YOUR_S32DS_INSTALL_PATH]\S32DS_Power_v2017.R1\Cross_Tools\powerpc-eabivle-4_9\powerpc-eabivle\share\docs\pdf\
Here is info about PPC EABI: https://www.nxp.com/docs/en/application-note/PPCEABI.pdf
Jiri
4 返答(返信)
3,846件の閲覧回数
jiri_kral
in which MCU you are interested in? You can start with this reference manual: https://www.nxp.com/docs/en/reference-manual/e200z4RM.pdf
Jiri
3,846件の閲覧回数
flyskyr丶
I'm using MPC5746R. So ,your recommendation is correct.  But I also want to get ABI & pseudo-ops documents.
please!
thank you!
3,847件の閲覧回数
jiri_kral
Jiri
3,846件の閲覧回数
flyskyr丶
Tanks for your help !
