How to compile your own library to use in the s32v234 environment
1,645 次查看
chenhailiang_ca
I wrote a library function, compiled with gcc to generate .a and .so library files, found that can not be used in the s23v234 environment, how to compile in order to use under s32v?
标记 (3)
1,555 次查看
chenhailiang_ca
it seems this prooblem has been solved. the library must be rebuild under the s32v environment because the gcc version under s32v is different from gcc under linux os.
1,555 次查看
jiri_kral
what is your gcc version and operating system?
Jiri
1,556 次查看
chenhailiang_ca
