How to Erase Flash with S32DS, PEMICRO and MPC5777M
3,145件の閲覧回数
Daniel_Wax
I am trying to erase flash before programming with PE Multilink in S32Design Studio.
Looking at
C:\NXP\S32DS_Power_v2017.R1\eclipse\plugins\com.pemicro.debug.gdbjtag.ppc_1.7.3.201803261737\win32\gdi\P&E\nxp_mpc5777m_1x32x1984k_cflash.pcp
There does not seem to be any scripting to erase flash sectors.
Other chips seem to have some support although most seem to be commented out.
Calypso has:
;Low Blocks(0..B) 5-16k,2-32k,4-64k
;USER=LB Low Block Erase    1Block >   /00000000/0000000B/
;High Blocks(0..E) 14-256k
;USER=HB High Block Erase   2Block >   /00000000/0000000E/
Where if needing to enable, the lines with ÜSER= would not be commented.
The problem is that every time I program the part with a new flash binary all my old register setting are still maintained.  Maybe there is a different way to fully blow away the chip prior to flashing a new binary??
2,473件の閲覧回数
jiri_kral
Hi Daniel,
I'm afraid that erase Flash only by PE Micro is still not supported. The only known workaround is flash empty binary file for full flash address space.
Jiri
