How do I deconfigure the adc port
Detective
Why can't the ADC port that I configured before be cancelled normally? enable or disable automatic? It can only be tilted. I can switch the pin to turn it off, but I don't want to change its purpose. How can I cancel the adc normally1.png2.png3.png
VaneB
Hi @Detective
Could you help me with the following information?
  • MCU you are using.
  • Software
  • IDE version
Also, when you said "enable or disable automatic" is it during run time or just in the configurations stage?
B.R.
VaneB
