How can S32K define a variable in a specified address?
2,878 次查看
zhengjianfei
Sometimes we need to define a variable in a specified address,but how to do this?The MCU is S32K144 and IDE is S32DS V2.0. I have tried to use the following method :1.unsigned char temp_A@0x00.  2.u8 sram[200] __attribute__((at(0x20002000)));   ,but it did not work!So dose anyone have any idea about this problem,thanks very much!
2,444 次查看
jiri_kral
you need to create custom section in linker file and add your variable like this:
__attribute__ ((section(".your_section"))) unsigned char your_variable;
You can look at this thread - https://community.nxp.com/message/971236
Jiri
2,444 次查看
zhengjianfei
Hi Jiri,thanks!
