How To Solve The Build Errors about Create New Project from Example ‘RSDK_S32DS_template’
4,144 次查看
jone_yang
HI,
   I follow the Step:"HOWTO: Create New Project from Example ‘RSDK_S32DS_template’" Create my Project successfully. Link: https://community.nxp.com/t5/S32-Design-Studio-Knowledge-Base/HOWTO-Create-New-Project-from-Example-...
but build all the project,Many errors occurred. How to solve it?
The RSDK version is
标记 (1)
5 回复数
4,108 次查看
jone_yang
i update the code for the projects by suggest,then build again.
the another errors occured!
4,139 次查看
lukaszadrapa
it looks like the files are not generated. You need to update the code for the projects:
lukaszadrapa_0-1661415910590.pnglukaszadrapa_0-1661415910590.pnglukaszadrapa_1-1661415931101.pnglukaszadrapa_1-1661415931101.png
Lukas
4,106 次查看
jone_yang
add on the package :"BBE32 DSP Add-on package 1.2.0 for S32 Design Studio 3.4 Update 1",build again,then license error occured.
4,085 次查看
jiri_kral
did you download and install LAX compiler?
Jiri
标记 (1)
4,083 次查看
jone_yang
Hi, the LAX compiler installed
