Hardware floating-point operations
ソリューションへジャンプ
2,475件の閲覧回数
zhangchun
Hello
I am using S32DS to build a motor Control engineering based on s32K144. This project involves a lot of floating point operations. How can I configure S32DS to support floating point operations
Thank's!
タグ(1)
2,451件の閲覧回数
Robin_Shen
Hi zhangchun,
Please refer to the discussion in Floating point instructions on s32k146 processor
Robin
2 返答(返信)
2,452件の閲覧回数
Robin_Shen
Hi zhangchun,
Robin
2,434件の閲覧回数
zhangchun
@Robin_Shen
Thank you for your reply
After using hardware floating-point operations, the time consumption of a portion of the code that heavily utilizes floating-point operations has changed from 105us to 73us. Is this reasonable?
