File flashing in s32 design studio
3,085件の閲覧回数
supriyaborchate
I want to know how to flash the file in S32k144 EVB board by using s32 design studio. I m facing error as,
"Remote communication Error : Target disconnected" No error.
Kindly share the steps for flashing the files in s32
ラベル(2)
2,791件の閲覧回数
jiri_kral
open debug configurations, select your debug target on the left side, check if OpenSDA PE Micro is detected and click on debug button:
Also make sure that you have selected power from USB - J107 jumper on 2-3 (closer to USB connector). There is no special settings needed.
Can you please attach output from your debug console?
Jiri
