Example Project in S32 Design Studio 3.5
hemanths
Hello Friends,
I have recently installed the S32DS version 3.5. But I can't find any example project in the design studio. Can somebody help me how to access these example projects? I have attached the screenshot of the pop-up when I select the project from the example option.
Thanks in advance!
Tags (2)
lukaszadrapa
Hi Hemanth,
you need to install RTD package first. Please follow the steps in this guide:
https://www.nxp.com/document/guide/getting-started-with-the-real-time-drivers-rtd:GS-AUTOMOTIVE-RTD
Lukas
BGauthier
Good morning, Hemanths,
(Sorry, I don't have the right to attach picture)
In the project explorer window:
  • Right click->New project...
  • You will get a pop-up windows title "New Project" "Select a wizard"
  • Under "S32DS Projects", select "S32DS Project from Example" then "Next"
  • You'll get the following title in the pop-up window: "Create S32DS Project from example"
  • You can then search the project type/key word in the 'Enter search text' for instance M7
Bruno
hemanths
Hi Bruno,
I followed the steps you mentioned. But still, I can't find the example projects. I have attached screenshots of the pop-up window.
Thanks and Regards
Hemanth
lukaszadrapa
Hi Hemanth,
Lukas
