Error while opening a new project ( freemaster_cfg.h not found )
aquant
Greetings.
I'm trying to open a new project with freemaster's sdk enabled, but for some reason I'm met with this error, where the said file freemaster_cfg.h file is not to be found in the location. I have also separately installed the freemaster tool from nxp, but to no avail.
Please help me out.
Thanks and regards,
Aquant
stanish
Hi Aquant,
Can you possibly describe how did you create or import the project? Where is your workspace located?
I'd suggest to open a new workspace in a custom folder where you have write access rights and create or import a project again.
