Detailed introduction of linker file (. ld) command
2,790件の閲覧回数
amei_liu
I am now using S32R45EVB for development. Can you provide me with some detailed documentation about the linker file (. ld)?
2,762件の閲覧回数
lukaszadrapa
Hi @amei_liu
you can find the documentation in build tools folder in S32DS:
c:\NXP\S32DS.3.5\S32DS\build_tools\gcc_v10.2\gcc-10.2-arm32-eabi\arm-none-eabi\share\docs\pdf\ld.pdf
Lukas
2,763件の閲覧回数
lukaszadrapa
Hi @amei_liu
Lukas
