Debugging S32K148 with iC5000
1,828 次查看
michael_pan
I'm trying to build an application in S32 Design Studio and debug it with iC5000. I'm using S32K148 evaluation board, so I created new project and selected S32K148 in EmbSys. The iC5000 refuses to download the resulting elf file and says the file is for Cortex-A5. I tried both "bare-metal" and standard S32DS toolchains, same result. Also I know for sure that the iC5000 works and is capable to debug this board, because I have a different toolchain (not using S32 Design Studio) that creates elf and I'm able to debug it in this setup.
Thank you in advance
Michael Pan
标记 (4)
1,684 次查看
peterkang2006
Hello Michael,
        Have you solved your problems? If not, please contact me, maybe i can give your some suggestions.
Thanks.
