Debugger error using PE micro universal multilink FX with s321.2 v
1,882 次查看
vrushalitaklika
I tried to debug using s32 V1.2 to MPC5777C using PE micro uiversal multilink Fx.
PE micro plugin version i s com.pemicro.debug.gdbjtag.ppc_1.6.9.201706282002
while I enter debug, it throws errror,
Could not determine GDB version.
Vrushali
1,661 次查看
jiri_kral
Hi Vrushali,
I have the same configuration - but without any problem with GDB version. My gdb version is 7.8.2  (you can get version by starting gdb executable -> [YOUR_S32DS_INSTALL_PATH]\Cross_Tools\powerpc-eabivle-4_9\bin\powerpc_eabivle_gdb.exe )
Do you have installed all PE Micro updates?
Jiri
