Codewarrior project to S32 Design studio
3,355 次查看
maximillion
I want to open Code Warrior project in S32 Design Studio. It is possible? If it yes how can I do
thanks
7 回复数
3,340 次查看
maximillion
Thanks for answering
Also, here is my second situation.
I have to open Code Warrior project in Kinetis Design Studio 3 IDE. Could you share with me AN about this topic?
3,320 次查看
Robin_Shen
3,309 次查看
maximillion
Firstly thanks for quick answer.
 I try to import Code Warrior Project which is complied GCC complier but I have an error.
GCC complier properly for kinetis design isn't it? I thought yes this error still exist.
How can I fix that? Could you give me tricks about this topic.
标记 (1)
3,278 次查看
Robin_Shen
Did you click Convert CodeWarrior project file...?
3,267 次查看
maximillion
Yes I clicked after that I included LIN_Stack libraries.
But I have error and warrnings. Code warrior used to FLASH for debug. Maybe this is problem?
I use to your recommended document actually step by step but cant still convert. Where is the problem?
标记 (2)
3,212 次查看
Robin_Shen
Sorry I am not familiar with this part, I suggest submitting this question to CodeWarrior for MCU.
3,348 次查看
Robin_Shen
I recommend you to read: AN5282 CodeWarrior to S32 Design Studio (S32DS) Migration Guide
Hope it helps.
Robin
