Build variable not usable in external tools configuration
2,398件の閲覧回数
roy_vanlierop
I'm trying to automate running Seggers Ozone by putting the build configuration in a variable.
And then using it in an external tool configuration:
This yields the following error:
Hardcoding the value is not what I want, how do I fix this?
ラベル(2)
2,375件の閲覧回数
jiri_kral
thanks for report, I can reproduce your issue. It looks that manually added Env/Build variables aren't visible for Eclipse system. I'll create JIRA ticket for that. Unfortunately I didn't found any workaround - looks that even OS environment variables aren't visible for External tool config.
Jiri
2,376件の閲覧回数
jiri_kral
Jiri
