Build problems
Build problems
supra0309
HI: When I build project, it occurred in problems(Description Resource Path Location Type
make: *** [makefile:61: VCU_Rev1_1_EJDMC_201229_Mikai.elf] Error 1 VCU_Rev1_1_EJDMC_201229_Mikai C/C++ Problem
). But I can't find any bugs in .c/.h file. Please tell me how to fix it, thanks. Best Regards, Xantia
supra0309
HI:
I'm using S32DS with MCU 5746R, and it showed there's no bug in my code. But just can't build elf file.
Xantia
jiri_kral
Hi Xantia,
can you please share full output from your build console - ideally in verbose mode?
Jiri
supra0309
Hi:
Yes, it's in verbose mode.
Xantia
jiri_kral
okay, can you please share output from build console? It looks like this one:
Select all text and copy/paste it here on community thread.
Jiri
lukaszadrapa
which device and which tool is that?
Lukas
