HOWTO: Update OpenSDA Firmware on EVB
If your EVB with OpenSDA debugger can't start debug session - you can try to update OpenSDA firmware on your board.
           DEBUG-OPENSDA-E200_Pemicro_v110.SDA for DEVKIT-MPC5748G
           MSD-DEBUG-EVB-S32K144_Pemicro_v119.SDA for S32K144EVB
  • Press and hold SW3 (Reset for S32K144EVB) button and connect OpenSDA connector on EVB to PC. New BOOTLOADER Drive should appear on your PC.
  • Copy .SDA file in BOOTLOADER drive
  • Reset EVB.
More details you can find in "Updating the OpenSDA Firmware.pdf" file. It is part of downloaded zip file from PE Micro web pages.
Comments
I tried to FRDM-KE06Z as your explaination. however, it failed programming the bootloader.
and I has a Multilink unversal FX. How to program the bootloader via SDA port for openSDA MCU.
There are only *.sda files such as MSD-DEBUG-FRDM-KE06Z_Pemicro_v118.SDA and MSD-DEBUG-FRDM-KE06Z_Pemicro_v114.SDA.
No ratings
Version history
Last update:
‎02-21-2018 06:38 AM
Updated by:
