This simple example shows how to attach GPIO Interrupt handler to particular GPIO Pin. Example is for S32K148 EVB and uses SW4 connected to PTC 13 and Green LED connected to PTE 22. Pressing SW4 invoke interrupt and Interrupt handler toggles Green LED.
Pay attention to
https://www.nxp.com/docs/en/application-note/AN5413.pdf
Section
2.1 Hello World
shows GPIO toggling example
If you were interested, section
2.5 Timed I/O (FTM)
shows using of FTM module
