what's the minimal standby current?
1,653件の閲覧回数
George_Ye
I use the MC9S12ZVL, what's the minimal standby current?The datasheet  have not mentioned it.
2 返答(返信)
1,650件の閲覧回数
lama
This value is not defined and it is absolutely useless. For you as an engineer is important maximum value of the power save energy mode as a guaranteed value which will not be higher. All other cases are better. The value is important for design of other, for example supply, devices.
Ladislav
1,642件の閲覧回数
George_Ye
Hi @lama ,
  According to what you said, the static current is not defined, but I need to know the minimum current when the MCU enters the stop mode. I mean, Why is it not defined, when the MCU is in stop mode, is its static current a fixed value?
