using the CW MCU v11.1 development platform, the PE tool failed to burn
1,922 次查看
zhouqicheng
Hello, using the CW MCU v11.1 development platform, the PE tool failed to burn and the circuit board has 5V. The following interface always pops up. How can I solve this problem
1,908 次查看
lama
if you have a problem with P&E USB Multilink Universal (firmware update), then you should ask P&E support. www.pemicro.com
However.....
I suppose you use Windows 10.
Did it work before?
Have you plugged the cable in correct orientation into the board?
Are you using your own board or an EVB?
Ladislav
