send retry and bus off
1,689件の閲覧回数
han_shuai
About Bus-Off, try to send 32 times with Stuff Error, bus off recover called, after 4 times of bus off recover, try to send 24 times with Stuff Error, bus off recover called, that's why?
---- log ----
Time Chn ID Name Event Type Dir DLC Data length Data
[+] 0.074798 CAN 1 CAN Error RxErr ECC: 100000101xxxxx, Stuff Error, Bit Position = 18
[+] 0.000074 CAN 1 CAN Error RxErr ECC: 100000101xxxxx, Stuff Error, Bit Position = 18
[+] 0.000088 CAN 1 CAN Error RxErr ECC: 100000101xxxxx, Stuff Error, Bit Position = 17
[+] 0.000089 CAN 1 CAN Error RxErr ECC: 100000101xxxxx, Stuff Error, Bit Position = 17
[+] 0.053483 CAN 1 CAN Error RxErr ECC: 100000101xxxxx, Stuff Error, Bit Position = 18
[+] 0.052474 CAN 1 CAN Error RxErr ECC: 100000101xxxxx, Stuff Error, Bit Position = 18
[+] 0.052476 CAN 1 CAN Error RxErr ECC: 100000101xxxxx, Stuff Error, Bit Position = 18
[+] 0.000124 CAN 1 CAN Error RxErr ECC: 100000101xxxxx, Stuff Error, Bit Position = 18
[+] 0.000138 CAN 1 CAN Error RxErr ECC: 100000101xxxxx, Stuff Error, Bit Position = 17
[+] 0.000078 CAN 1 CAN Error RxErr ECC: 100000101xxxxx, Stuff Error, Bit Position = 17
[+] 0.000077 CAN 1 CAN Error RxErr ECC: 100000101xxxxx, Stuff Error, Bit Position = 17
[+] 0.052820 CAN 1 CAN Error RxErr ECC: 100000101xxxxx, Stuff Error, Bit Position = 18
[+] 1.002742 CAN 1 CAN Error RxErr ECC: 100000101xxxxx, Stuff Error, Bit Position = 18
1,542件の閲覧回数
han_shuai
initialization for recovery.
