s12zvml31 Motor driver transplant
1,902 次查看
mine233
I want to transplant the motor driver program based on s12zvml128 to s12zvml31. The modified program can be burned to the development board of s12zvml31, but the motor cannot run, and the program transplanted to s12zvml31 cannot enter the ADC interrupt, so the foc algorithm cannot be performed. Do the ADC, timer, and interrupt of s12zvml128 and s12zvml31 need to be configured accordingly?
1,890 次查看
lama
I hope this AN will help you...
https://www.nxp.com/docs/en/application-note/AN5330.pdf
Ladislav
1,877 次查看
mine233
According to the modification of this document, the program can now run normally on s12zvml31, but the oil pump motor still cannot work normally. Do you need to send external signals through freemaster software to drive the motor?
