S12Z MagniV Serial Bootloader Interface.
2,275件の閲覧回数
itsnewforme
I've downloaded the AN5389SW. But, I'm unable to find the S12Z MagniV Serial Bootloader Interface. Please provide the path for this interface.
2 返答(返信)
2,260件の閲覧回数
lama
I suppose you have already been able to find following response on these pages
I would like to recommend you to use the newer application note AN12086 - Simple Serial Bootloader for S12Z
https://www.nxp.com/docs/en/application-note/AN12086.pdf
The software of AN12086:
https://www.nxp.com/docs/en/application-note-software/AN12086SW.ZIP
However, the software of the AN4723 can be downloaded here: http://www.nxp.com/files/microcontrollers/doc/app_note/AN4723_SW.zip
Unfortunately the last link does not work so I put the files here. The files are part of the package.
Best regard, Ladislav
2,253件の閲覧回数
itsnewforme
Thanks a ton
