s12x can communication
1,297件の閲覧回数
zhuwei
chip's mode is s12xdp512,s12x can't communitcate by canbus after worked for several moths.I have checked hardware around the mcu,but found no problems. And i download the s19 file,found it can't work well.pls introduce some ideas to find the cause,thks.
1,281件の閲覧回数
lama
the standard approach....
Could you please share MCU environment schematic design with visible part numbers?
Moreover...share BUSCLK, PLLCLK, PLL setup constants, oscillator type if not visible at schematics.
If it is not possible to share it with public then you should create a case at:
https://www.nxp.com/support/support:SUPPORTHOME?tid=sbmenu
log in and
Ladislav
