resolver connection
resolver connection
3,799件の閲覧回数
bezzie
hi,
   i am trying to connect resolver with MCSXSR1CS12ZVM evaluation board. is there inbuild excitation circuit for resolver. can i test resolver output on DSO by just connecting on evaluation board or  need to do some code for it. is there any example code available to get resolver position.
https://www.nxp.com/document/guide/get-started-with-the-mcsxsr1cs12zvm-evaluation-board-for-3-phase-...
4 返答(返信)
3,090件の閲覧回数
jchabu
I am interested in the NXP software resolver. How could you claim that it is rated ASIL D(D) when safety mechanisms defined are related to only one sensor. For example, if the resolver measures 30 degrees (amplitude range, non-stuck signal, DC shift, zero-crossing, unit circle checks are correct) when the exact value is 40 degrees. How can you detect that?
3,628件の閲覧回数
ImranAviconn
can you please provide the software example for resolver based feedback control for the MCSXSR1CS12ZVM evaluation board
3,713件の閲覧回数
lama
See attached
Ladislav
3,613件の閲覧回数
ImranAviconn
Can you please share any example code for resolver feedback based control using the MCSXSR1CS127ZVM evaluation board
