problem with pwm module of mc9s12dg25b !
1,473件の閲覧回数
jeffzxg
hi
   I have a problem with pwm module  of mc9s12dg256. if pwm waveform is closed by PWME register, does the output of pwm module have fixed output (high level or low level output, that decided by the output level when PWME is set to 0), or have other output state?
        thanks!
721件の閲覧回数
kef
Specialist I
When PWM bit is clear, then corresponding data direction and port register bits (DDRP and PTP probably) determine the state of pin.
