include file problems
1,575 次查看
OGUZB
I have installed the software according to the Quick Start GuideS12ZVML-MINIKIT.
I try to build software by using CodeWarior but some libraries that are given in below could not be found by CodeWarior.
#include "mlib.h"
#include "gflib.h"
#include "SWLIBS_Config.h"
If you help me with that topic, it will be very pleasant.
1,548 次查看
danielmartynek
Hi @OGUZB,
The path to the AMMCLIB is probably incorect.
Open the properties of the project in CW11 (right-click on the project -> properties).
Change the paths to the AMMCLIB installed on your PC.
