import example project
2,449 次查看
bezzie
hi,
i m trying to import example projects in code warrior ide.
https://www.nxp.com/document/guide/get-started-with-the-mcsxsr1cs12zvm-evaluation-board-for-3-phase-...
i am facing issue with build. i don' t know what i did wrong. there are approx. 100 error with "build project". can you tell me right way to import example project in ide
2,315 次查看
bezzie
i want to connect resolver with this board. is there any example code that i can follow to do it. as in schematic diagram there is option for resolver available.
2,347 次查看
danielmartynek
Hi @bezzie,
Did you installed the latest AMMCLIB?
The installer should ask you to download and install the library:
BR, Daniel
2,316 次查看
bezzie
thank you. issue solved.
