how to make ADC configuration with MC9S12ZVC
2,756件の閲覧回数
sunkemiao
I have made ADC configuratin according to  soft Demo AN5162 .Now I can use four channels to sample four groups data,but when I want to add a channel to sample data,the MC9S12ZVC do not work under Debugging.You can look at ADC initialization part of my code.
6 返答(返信)
2,358件の閲覧回数
vinitekghare
Where to get AN5162??sunkemiao
2,358件の閲覧回数
danielmartynek
I think you are looking for
AN5168 Using the ADC Module in S12ZVM
AN5168SW
2,358件の閲覧回数
vinitekghare
Hi Daniel,
Thank you..
Vinit
2,358件の閲覧回数
danielmartynek
You should use End_of_list command (CMD_SEL = 0xCx) only for the last channel, after that the measurement will be terminated. Also, make sure the RAM address you use to allocate lists is not address of the stack.
2,358件の閲覧回数
sunkemiao
Hi,Daniel:
I follow your advice.I use End_of list command only for the last channel.Now I can sample data. I am very happy,because the problem have perlexed me for long time.
2,358件の閲覧回数
sunkemiao
Hi,Daniel :
I have made the
