XGATE semaphore question
3,316 次查看
roberthiebert
Senior Contributor I
MC9S12XEP100, CW Special Edition, USBDM, XGATE in RAM, coding in relocatable assembler.
I have a project that was written in absolute assembler which uses a lot of interrupts. It runs just fine now, but I want to incorporate XGATE to handle most, if not all of the interrupts. Why? Probably just to see if I can. To that end, I have been able to convert the project to relocatable assembler, (which wasn't easy for me) but it seems to work.
Anyway, I spend a lot of time studying the reference manuals and AN2685, but I 'm still not quite clear on the basics of XGATE semaphores.
When I change an interrupt service routine to be serviced by XGATE instead of the CPU, I have read that semaphores need to be involved, but I m not clear under just what circumstances.
Do they need to be used just when a variable is modified within an ISR serviced by XGATE, and, modified by an ISR service by the CPU?
Or.
Also, when a variable is modified within an ISR serviced by XGATE, but it is only used by the CPU, but not modified?
Robert
3,287 次查看
lama
Semaphores are needed only when both cores (S12X and XGATE) access the same shared resource, typically a variable in RAM. The are needed to avoid simultaneous R/W from both cores. For example, CPU writes some data in one or two steps and XGATE reads them at the same moment. Data consistency is not guaranteed.
Use semaphores when:
  1. A variable is modified by both XGATE and S12X ISRs.
Example: A status flag or counter updated by both cores. Or writing to a port.
  1. A variable is modified by one core and read by the other, and the read must be consistent.
Example: A buffer index updated by XGATE and read by S12X in a loop.
You do not need semaphores when:
  • A variable is only modified by XGATE, and only read by S12X, and consistency is not critical (e.g., occasional stale reads are acceptable).
  • A variable is only accessed by one core (either read or write).
Note, I found in my old code following. It is probably not important for some mask sets but better to implement to be sure it works everywhere.
....  *.cxgate module
interrupt void PIT0isr(void)
      //--- Protected software region starts     // AN2685.pdf
      // use this
      asm LOOP1:
      asm SSEM #0 // try to lock semaphore 0
      asm SSEM #0 // try to lock semaphore 0     // once more due to internal silicon bug
      asm BCC LOOP1 // retry if locked
      //or this
      //asm SSEM #0 // try to lock semaphore 0
      //asm SSEM #0 // try to lock semaphore 0     // once more due to internal silicon bug
      //asm BCC PIT0isr_RTI // return without flag clearing to enable service of an interrupt with higher priority
      asm CSEM #0 // release semaphore
asm PIT0isr_RTI:
      PITTF = 0x01; // clear interrupt flag of PIT0isr
Ladislav
3,288 次查看
lama
      // use this
      asm LOOP1:
      //or this
asm PIT0isr_RTI:
Ladislav
3,270 次查看
roberthiebert
Hi Ladislav,
Thanks for the clarification. That's how I thought it should work, but I wasn't sure.
Robert
%3CLINGO-SUB%20id%3D%22lingo-sub-2195354%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EXGATE%20%E4%BF%A1%E5%8F%B7%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2195354%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EMC9S12XEP100%E3%80%81CW%20%E7%89%B9%E5%88%AB%E7%89%88%E3%80%81USBDM%E3%80%81RAM%20%E4%B8%AD%E7%9A%84%20XGATE%E3%80%81%E5%8F%AF%E9%87%8D%E5%AE%9A%E4%BD%8D%E6%B1%87%E7%BC%96%E5%99%A8%E7%BC%96%E7%A0%81%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%9C%89%E4%B8%80%E4%B8%AA%E7%94%A8%E7%BB%9D%E5%AF%B9%E6%B1%87%E7%BC%96%E7%A8%8B%E5%BA%8F%E7%BC%96%E5%86%99%E7%9A%84%E9%A1%B9%E7%9B%AE%EF%BC%8C%E5%85%B6%E4%B8%AD%E4%BD%BF%E7%94%A8%E4%BA%86%E5%A4%A7%E9%87%8F%E4%B8%AD%E6%96%AD%E3%80%82%E7%8E%B0%E5%9C%A8%E8%BF%90%E8%A1%8C%E5%BE%97%E5%BE%88%E5%A5%BD%EF%BC%8C%E4%BD%86%E6%88%91%E6%83%B3%E7%BB%93%E5%90%88%20XGATE%20%E6%9D%A5%E5%A4%84%E7%90%86%E5%A4%A7%E9%83%A8%E5%88%86%EF%BC%88%E5%A6%82%E6%9E%9C%E4%B8%8D%E6%98%AF%E5%85%A8%E9%83%A8%EF%BC%89%E4%B8%AD%E6%96%AD%E3%80%82%E4%B8%BA%E4%BB%80%E4%B9%88%EF%BC%9F%E4%B9%9F%E8%AE%B8%E5%8F%AA%E6%98%AF%E6%83%B3%E7%9C%8B%E7%9C%8B%E6%88%91%E8%83%BD%E4%B8%8D%E8%83%BD%E5%81%9A%E5%88%B0%E3%80%82%E4%B8%BA%E6%AD%A4%EF%BC%8C%E6%88%91%E5%B7%B2%E7%BB%8F%E8%83%BD%E5%A4%9F%E5%B0%86%E9%A1%B9%E7%9B%AE%E8%BD%AC%E6%8D%A2%E4%B8%BA%E5%8F%AF%E9%87%8D%E7%BD%AE%E6%B1%87%E7%BC%96%E7%A8%8B%E5%BA%8F%EF%BC%88%E8%BF%99%E5%AF%B9%E6%88%91%E6%9D%A5%E8%AF%B4%E5%B9%B6%E4%B8%8D%E5%AE%B9%E6%98%93%EF%BC%89%EF%BC%8C%E4%BD%86%E5%AE%83%E4%BC%BC%E4%B9%8E%E5%8F%AF%E4%BB%A5%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%3E%E6%97%A0%E8%AE%BA%E5%A6%82%E4%BD%95%EF%BC%8C%E6%88%91%E8%8A%B1%E4%BA%86%E5%BE%88%E5%A4%9A%E6%97%B6%E9%97%B4%E7%A0%94%E7%A9%B6%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E5%92%8C%20AN2685%EF%BC%8C%E4%BD%86%E6%88%91%E4%BB%8D%E7%84%B6%E4%B8%8D%E5%A4%AA%E6%B8%85%E6%A5%9A%20XGATE%20%E4%BF%A1%E5%8F%B7%E9%87%8F%E7%9A%84%E5%9F%BA%E7%A1%80%E7%9F%A5%E8%AF%86%E3%80%82%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E6%9B%B4%E6%94%B9%E4%B8%AD%E6%96%AD%E6%9C%8D%E5%8A%A1%E4%BE%8B%E7%A8%8B%EF%BC%8C%E4%BD%BF%E5%85%B6%E7%94%B1%20XGATE%20%E8%80%8C%E4%B8%8D%E6%98%AF%20CPU%20%E6%8F%90%E4%BE%9B%E6%9C%8D%E5%8A%A1%E6%97%B6%EF%BC%8C%E6%88%91%E8%AF%BB%E5%88%B0%20semaphores%20%E9%9C%80%E8%A6%81%E5%8F%82%E4%B8%8E%E5%85%B6%E4%B8%AD%EF%BC%8C%E4%BD%86%E6%88%91%E4%B8%8D%E6%B8%85%E6%A5%9A%E5%9C%A8%E4%BB%80%E4%B9%88%E6%83%85%E5%86%B5%E4%B8%8B%E3%80%82%3C%2FP%3E%3CP%3E%E6%98%AF%E5%90%A6%E5%8F%AA%E6%9C%89%E5%9C%A8%20XGATE%20%E6%9C%8D%E5%8A%A1%E7%9A%84%20ISR%20%E4%B8%AD%E4%BF%AE%E6%94%B9%E5%8F%98%E9%87%8F%E5%92%8C%20CPU%20%E6%9C%8D%E5%8A%A1%E7%9A%84%20ISR%20%E4%B8%AD%E4%BF%AE%E6%94%B9%E5%8F%98%E9%87%8F%E6%97%B6%E6%89%8D%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%E5%AE%83%E4%BB%AC%EF%BC%9F%3C%2FP%3E%3CP%3EOr%E3%80%82%3C%2FP%3E%3CP%3E%E5%8F%A6%E5%A4%96%EF%BC%8C%E5%BD%93%E4%B8%80%E4%B8%AA%E5%8F%98%E9%87%8F%E5%9C%A8%20XGATE%20%E6%9C%8D%E5%8A%A1%E7%9A%84%20ISR%20%E4%B8%AD%E8%A2%AB%E4%BF%AE%E6%94%B9%EF%BC%8C%E4%BD%86%E5%AE%83%E5%8F%AA%E8%A2%AB%20CPU%20%E4%BD%BF%E7%94%A8%E8%80%8C%E6%9C%AA%E8%A2%AB%E4%BF%AE%E6%94%B9%E6%97%B6%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E7%BD%97%E4%BC%AF%E7%89%B9%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2195950%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20XGATE%20semaphore%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2195950%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%8B%89%E8%BF%AA%E6%96%AF%E6%8B%89%E5%A4%AB%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E6%BE%84%E6%B8%85%E3%80%82%E6%88%91%E6%83%B3%E5%BA%94%E8%AF%A5%E6%98%AF%E8%BF%99%E6%A0%B7%E7%9A%84%EF%BC%8C%E4%BD%86%E6%88%91%E4%B8%8D%E7%A1%AE%E5%AE%9A%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E7%BD%97%E4%BC%AF%E7%89%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2195763%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20XGATE%20semaphore%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2195763%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E5%8F%AA%E6%9C%89%E5%BD%93%E4%B8%A4%E4%B8%AA%E5%86%85%E6%A0%B8%EF%BC%88S12X%20%E5%92%8C%20XGATE%EF%BC%89%E8%AE%BF%E9%97%AE%E7%9B%B8%E5%90%8C%E7%9A%84%E5%85%B1%E4%BA%AB%E8%B5%84%E6%BA%90%3C%2FSTRONG%3E%EF%BC%88%E9%80%9A%E5%B8%B8%E6%98%AF%20RAM%20%E4%B8%AD%E7%9A%84%E5%8F%98%E9%87%8F%EF%BC%89%E6%97%B6%EF%BC%8C%E6%89%8D%E9%9C%80%E8%A6%81%20Semaphores%E3%80%82%E9%9C%80%E8%A6%81%E5%AE%83%E4%BB%AC%E6%9D%A5%E9%81%BF%E5%85%8D%E4%B8%A4%E4%B8%AA%E5%86%85%E6%A0%B8%E5%90%8C%E6%97%B6%E8%BF%9B%E8%A1%8C%20R%2FW%20%E6%93%8D%E4%BD%9C%E3%80%82%E4%BE%8B%E5%A6%82%EF%BC%8CCPU%20%E5%88%86%E4%B8%80%E5%88%B0%E4%B8%A4%E6%AD%A5%E5%86%99%E5%85%A5%E6%9F%90%E4%BA%9B%E6%95%B0%E6%8D%AE%EF%BC%8CXGATE%20%E5%9C%A8%E5%90%8C%E4%B8%80%E6%97%B6%E5%88%BB%E8%AF%BB%E5%8F%96%E8%BF%99%E4%BA%9B%E6%95%B0%E6%8D%AE%E3%80%82%E6%95%B0%E6%8D%AE%E4%B8%80%E8%87%B4%E6%80%A7%E5%BE%97%E4%B8%8D%E5%88%B0%E4%BF%9D%E8%AF%81%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E%E5%9C%A8%E4%B8%8B%E5%88%97%E6%83%85%E5%86%B5%E4%B8%8B%E4%BD%BF%E7%94%A8%E4%BF%A1%E5%8F%B7%E4%BC%A0%E9%80%92%E5%99%A8%3C%2FSTRONG%3E%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%3CSTRONG%3EXGATE%20%E5%92%8C%20S12X%20ISR%20%E9%83%BD%E4%BC%9A%E4%BF%AE%E6%94%B9%E5%8F%98%E9%87%8F%E3%80%82%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%E4%BE%8B%E5%A6%82%E7%94%B1%E4%B8%A4%E4%B8%AA%E5%86%85%E6%A0%B8%E6%9B%B4%E6%96%B0%E7%9A%84%E7%8A%B6%E6%80%81%E6%A0%87%E5%BF%97%E6%88%96%E8%AE%A1%E6%95%B0%E5%99%A8%E3%80%82%E6%88%96%E5%86%99%E5%85%A5%E7%AB%AF%E5%8F%A3%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%3CSTRONG%3E%E4%B8%80%E4%B8%AA%E6%A0%B8%E5%BF%83%E4%BF%AE%E6%94%B9%E4%B8%80%E4%B8%AA%E5%8F%98%E9%87%8F%EF%BC%8C%E5%8F%A6%E4%B8%80%E4%B8%AA%E6%A0%B8%E5%BF%83%E8%AF%BB%E5%8F%96%E5%8F%A6%E4%B8%80%E4%B8%AA%E5%8F%98%E9%87%8F%3C%2FSTRONG%3E%EF%BC%8C%E8%80%8C%E4%B8%94%E8%AF%BB%E5%8F%96%E5%BF%85%E9%A1%BB%E4%B8%80%E8%87%B4%E3%80%82%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%E7%A4%BA%E4%BE%8B%E7%BC%93%E5%86%B2%E5%8C%BA%E7%B4%A2%E5%BC%95%E7%94%B1%20XGATE%20%E6%9B%B4%E6%96%B0%EF%BC%8C%E5%B9%B6%E7%94%B1%20S12X%20%E5%9C%A8%E5%BE%AA%E7%8E%AF%E4%B8%AD%E8%AF%BB%E5%8F%96%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E5%9C%A8%E4%B8%8B%E5%88%97%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E6%82%A8%3CEM%3E%E4%B8%8D%3C%2FEM%3E%E9%9C%80%E8%A6%81%20semaphores%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E5%8F%98%E9%87%8F%3CSTRONG%3E%E4%BB%85%E7%94%B1%20XGATE%20%E4%BF%AE%E6%94%B9%3C%2FSTRONG%3E%EF%BC%8C%3CSTRONG%3E%E4%BB%85%E7%94%B1%20S12X%20%E8%AF%BB%E5%8F%96%3C%2FSTRONG%3E%EF%BC%8C%3CSTRONG%3E%E4%B8%80%E8%87%B4%E6%80%A7%E5%B9%B6%E4%B8%8D%E9%87%8D%E8%A6%81%3C%2FSTRONG%3E%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8C%E5%81%B6%E5%B0%94%E7%9A%84%E9%99%88%E6%97%A7%E8%AF%BB%E5%8F%96%E6%98%AF%E5%8F%AF%E4%BB%A5%E6%8E%A5%E5%8F%97%E7%9A%84%EF%BC%89%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E4%B8%80%E4%B8%AA%E5%8F%98%E9%87%8F%3CSTRONG%3E%E5%8F%AA%E8%83%BD%E8%A2%AB%E4%B8%80%E4%B8%AA%E6%A0%B8%E5%BF%83%E8%AE%BF%E9%97%AE%3C%2FSTRONG%3E%EF%BC%88%E8%AF%BB%E5%8F%96%E6%88%96%E5%86%99%E5%85%A5%EF%BC%89%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%B3%A8%E6%84%8F%EF%BC%8C%E6%88%91%E5%8F%91%E7%8E%B0%E6%88%91%E7%9A%84%E6%97%A7%E4%BB%A3%E7%A0%81%E5%A6%82%E4%B8%8B%E3%80%82%E8%BF%99%E5%AF%B9%E6%9F%90%E4%BA%9B%E9%9D%A2%E5%85%B7%E5%A5%97%E4%BB%B6%E5%8F%AF%E8%83%BD%E5%B9%B6%E4%B8%8D%E9%87%8D%E8%A6%81%EF%BC%8C%E4%BD%86%E6%9C%80%E5%A5%BD%E8%BF%98%E6%98%AF%E5%AE%9E%E6%96%BD%E4%B8%80%E4%B8%8B%EF%BC%8C%E4%BB%A5%E7%A1%AE%E4%BF%9D%E5%AE%83%E5%9C%A8%E6%89%80%E6%9C%89%E5%9C%B0%E6%96%B9%E9%83%BD%E8%83%BD%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%0A%3CP%3E....%20%20*.cxgate%E6%A8%A1%E5%9D%97%3C%2FP%3E%0A%3CP%3E%E4%B8%AD%E6%96%AD%20void%20PIT0isr(void)%3C%2FP%3E%0A%3CP%3E%7B%3C%2FP%3E%0A%3CP%3E%20%20%20%20%20%20%2F%2F---%20%E5%8F%97%E4%BF%9D%E6%8A%A4%E8%BD%AF%E4%BB%B6%E5%8C%BA%E5%9F%9F%E5%BC%80%E5%A7%8B%20%2F%2F%20AN2685.pdf%3C%2FP%3E%0A%3CP%3E%20%20%20%20%20%2F%2F-----------------------------------------%3C%2FP%3E%0A%3CP%3E%20%20%20%20%20%20%2F%2F%20%E4%BD%BF%E7%94%A8%E8%BF%99%E4%B8%AA%3C%2FP%3E%0A%3CP%3E%20%20%20%20%20%20asm%20LOOP1%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%20%20%20%20%20%20asm%20SSEM%20%230%20%2F%2F%20%E5%B0%9D%E8%AF%95%E9%94%81%E5%AE%9A%E5%AF%84%E5%AD%98%E5%99%A8%200%3C%2FP%3E%0A%3CP%3E%20%20%20%20%20%20asm%20SSEM%20%230%20%2F%2F%20%E7%94%B1%E4%BA%8E%E5%86%85%E9%83%A8%E7%A1%85%E9%94%99%E8%AF%AF%EF%BC%8C%E5%86%8D%E6%AC%A1%E5%B0%9D%E8%AF%95%E9%94%81%E5%AE%9A%E5%AF%84%E5%AD%98%E5%99%A8%200%20%2F%2F%3C%2FP%3E%0A%3CP%3E%20%20%20%20%20%20asm%20BCC%20LOOP1%20%2F%2F%20%E9%94%81%E5%AE%9A%E5%90%8E%E9%87%8D%E8%AF%95%3C%2FP%3E%0A%3CP%3E%20%20%20%20%20%20%2F%2F-----------------------------------------%3C%2FP%3E%0A%3CP%3E%20%20%20%20%20%20%2F%2For%20this%3C%2FP%3E%0A%3CP%3E%20%20%20%20%20%20%2F%2Fasm%20SSEM%20%230%20%2F%2F%20%E5%B0%9D%E8%AF%95%E9%94%81%E5%AE%9A%E5%AF%84%E5%AD%98%E5%99%A8%200%3C%2FP%3E%0A%3CP%3E%20%20%20%20%20%20%2F%2Fasm%20SSEM%20%230%20%2F%2F%20%E7%94%B1%E4%BA%8E%E5%86%85%E9%83%A8%E7%A1%85%E9%94%99%E8%AF%AF%EF%BC%8C%E5%86%8D%E6%AC%A1%E5%B0%9D%E8%AF%95%E9%94%81%E5%AE%9A%E5%AF%84%E5%AD%98%E5%99%A8%200%20%2F%2F%3C%2FP%3E%0A%3CP%3E%20%20%20%20%20%20%2F%2Fasm%20BCC%20PIT0isr_RTI%20%2F%2F%20%E8%BF%94%E5%9B%9E%E6%97%B6%E4%B8%8D%E6%B8%85%E9%99%A4%E6%A0%87%E5%BF%97%EF%BC%8C%E4%BB%A5%E4%BE%BF%E4%B8%BA%E4%BC%98%E5%85%88%E7%BA%A7%E6%9B%B4%E9%AB%98%E7%9A%84%E4%B8%AD%E6%96%AD%E6%8F%90%E4%BE%9B%E6%9C%8D%E5%8A%A1%3C%2FP%3E%0A%3CP%3E%20%20%20%20%20%20%2F%2F-----------------------------------------%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%20%20%20%20....%3C%2FP%3E%0A%3CP%3E%20%20%20%20.....%3C%2FP%3E%0A%3CP%3E%20%20%20%20....%3C%2FP%3E%0A%3CP%3E%2F%2F---------------------------------------------------------------------------------------------------------------------------------------------------%3CBR%20%2F%3E%20%7C%20%3CBR%20%2F%3E%20%230%3C%2FP%3E%0A%3CP%3Easm%20PIT0isr_RTI%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%20%20%20%20%20%20%2F%2F-----------------------------------------%3CBR%20%2F%3E%20PITTF%20%3D%200x01%3B%20%2F%2F%20%E6%B8%85%E9%99%A4%20PIT0isr%20%E7%9A%84%E4%B8%AD%E6%96%AD%E6%A0%87%E5%BF%97%3C%2FP%3E%0A%3CP%3E%7D%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E6%8B%89%E5%90%89%E6%96%AF%E6%8B%89%E5%A4%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E
