Writing/reading to/from non-volatile memory MC9S12XF512
已解决
跳至解决方案
2,502 次查看
thomasbelekokia
hi,
i'm using  MC9S12XF512 devices, trying to store small piece of data in non-volatile memory.
tried to adapt code for different devices but the most i could achieve is to store/read data in debug mode.
no success when not in a debug mode.
basically the idea is to start running running a device and once a switch is ON, store a byte of data in a non-volatile mem. Then power cycle, check memory, data is safely written in the memory.
perhaps there are people who have done it hundreds of times, so an idea/advice would be very helpful.
标签 (1)
1 解答
2,411 次查看
ZhangJennie
AN4258.pdf and AN4258SW include how to implement how to implement HCS12x non-volatile memory.
hope this can help
在原帖中查看解决方案
3 回复数
2,411 次查看
thomasbelekokia
Thanks for that.
I've just managed to get it working with AN3961SW & AN3961.
Will try now bootloaders that you suggested, I think if I combine two of those I'll get pretty much what I was expecting.
thanks again.
2,411 次查看
ZhangJennie
you are welcome!
2,412 次查看
ZhangJennie
hope this can help
