1,392件の閲覧回数
Sumit88
1,221件の閲覧回数
lama
I have created an example project (see attach) and tested it on the board.
You should check jumper setup on the board (described in the module main.c).
The solution is in polling mode.
The project is created under CodeWarrior 5.1.
Best regards, Ladislav.
