Why? Help,THANKS!
Why? Help,THANKS!
2,056 次查看
lihao
# define  BUS   (48000000)
# define  PRE  (64)
# define  CLK    ( BUS / (10000*PRE) )
main()
     unsigned int  A;
     A= CLK;
result:   A=CLK= 62411,    why? Help,Thank you!
1,974 次查看
kef
Specialist I
(int)10000 * (int)64 = (int)0xC400 = (int)-15360
(long)48000000 / (int)-15360 = -3125
(unsigned int)-3125 = 0xF3CB = 62411
Some UL's or typecasts are missing, try this:
# define  BUS   (48000000ul)
# define  CLK    ( BUS / (10000ul*PRE) )
1,975 次查看
kef
Specialist I
1,974 次查看
lihao
Thanks you very much!   Best wishes for you!
