Wake-up from pseudo stop mode and RAM retention for S1912ZVCA product
2,085件の閲覧回数
bhushanpatil
I am using S1912ZVCA19F0WKH (magni v 192kB) controller.
I have done this configuration for API to generate API interrupts
main()
/* Autonomous Periodical Interrupt initialisations. */
       /*CPMUACLKTR API clock trimming register*/
       CPMUACLKTR_ACLKTR0 = 1;
CPMUACLKTR_ACLKTR1 = 1;
CPMUACLKTR_ACLKTR2 = 1;
CPMUACLKTR_ACLKTR3 = 1;
CPMUACLKTR_ACLKTR4 = 1;
CPMUACLKTR_ACLKTR5 = 0;
       /*CPMUAPICTL API control register settings*/
CPMUAPICTL_APICLK = 0; //Clock source for API is ACLK
CPMUAPICTL_APIES = 1; //External wave form visible at pin (Reference: Pg 250)
CPMUAPICTL_APIEA = 1; //Waveform can be accessed externally
CPMUAPICTL_APIE = 1; //API interrupt enabled whenever APIR timeout happens.
CPMUAPICTL_APIF = 1; //Clear the interrupt flag by writing 1
       /*Select the time for API*/
       /* Refer to Pg no: 253 */
CPMUAPIRH = 0xE7;
       CPMUAPIRL = 0xFF;
/*CPMU clock initialisations*/
       CPMUCLKS_PSTP = 1; //Oscillator 4Mhz continues to run --> Pseudo stop mode
CPMUCLKS_CSAD = 1; // COP stopped in stop mode
CPMUCLKS_PRE = 1; //RTI enabled in pseudo stop mode
CPMUCLKS_PCE = 0; //COP disabled in Pseudo stop mode
       CPMUCLKS_RTIOSCSEL = 1; //RTI clock source is OSCCLK
CPMUCLKS_COPOSCSEL1 = 0;
CPMUCLKS_COPOSCSEL0 = 1; //COP clock source is OSCCLK
for(;;)
/*Set of instructions*/
CPMUAPICTL_APIFE = 1; //API is enabled; this bit is set to 1 to start API timer*/
__asm(ANDCC #0x6F);
__asm(STOP);  //Enter pseudo stop mode
Using the above configuration; I am able to get API interrupt without stop command in main function.
But if I use stop command device will not wake up once it enters stop mode.
I want to call main function again in API interrupt function without losing any ram data.
interrupt ISR_API( void )
       if (CPMUAPICTL_APIF)
/* Clear the interrupt flag. */
CPMUAPICTL_APIF = 1;     /* APIF. Clear the interrupt flag by writing 1. */
/*Call the operation to be performed*/
main();
Kindly help me regarding this.
Bhushan
3 返答(返信)
1,331件の閲覧回数
RadekS
!Hi Bhushan,
I can’t see anything wrong in your code except calling main() inside main() routine.
This might simply lead to the stack overflow.
How do you detect the MCU wake-up?
Please be aware that when MCU enters into stop mode, internal clocks are disabled and BDM interface connection is lost. So, the MCU wake-up cannot be debugged by debugger. You have to use some other signalization like LEDs, check ECLK signal, …
The STOP mode API wake-up example code is here:
https://community.nxp.com/docs/DOC-330295
Attached is simple example code for ACLK trimming.
I hope it helps you.
Radek
1,331件の閲覧回数
manishsangram
We are using S12ZVMC128
PE defined STOP function is called form main.
#define Cpu_SetStopMode() \
  /*lint -save  -e950 Disable MISRA rule (1.1) checking. */\
  {__asm(ANDCC #0x7F); __asm(STOP); } \
Can interrupts be lost ?
SCI is connected to a serial port but system does not respond to it (SCI RX). If the Stop call is removed it works fine.
1,331件の閲覧回数
RadekS
Hi Bhushan/Manish,
Idea: You call __asm(ANDCC #0x6F); command before STOP instruction. This way you clear I-bit and enable I-bit maskable interrupts. However, there is a 1-cycle (bus clock) delay in the clearing mechanism for the I bit so that, if interrupts were previously disabled, the next instruction after a CLI will always be executed, even if there was an interrupt pending prior to execution of the CLI instruction.
Coud you please try to add one or more __asm(NOP); commands between __asm(ANDCC #0x6F); and __asm(STOP); commands?
About SCI wake-up from stop mode:
The SCI module is gated from bus clock = SCI does not work in STOP mode. However, you could use input active edge interrupt feature as part of SCI for wake-up from STOP mode. So, you have to switch SCI to the alternative map by AMAP bit and set SCIACR1_RXEDGIE bit for enabling Receive Input Active Edge Interrupt. For example:
void Go_Stop(void)
  SCI0SR2 = 0x80;  //Alternative Map - The registers labelled SCIASR1 (0x0000),SCIACR1 (0x0001), SCIACR2 (0x00002) are accessible
  SCI0ACR1 = 0x80; //Receive Input Active Edge Interrupt Enable - RXEDGIF interrupt requests enabled
  SCI0ASR1 = 0x80; //clear Receive Input Active Edge Interrupt Flag - RXEDGIF
  SCI0SR2 = 0x00;  //Back from Alternative Map
  asm STOP;        //Go to stop mode
In SCI interrupt routine you have to check RXEDGIF flag, clear them and disable this kind of interrupt. For example:
if(SCI0ASR1 & SCI1ASR1_RXEDGIF_MASK)
    SCI0ACR1 = 0x00; //Receive Input Active Edge Interrupt Disable - RXEDGIF interrupt requests disabled
Radek
